Build List
Build Author Elias Ramburger Views 640
600 volume 3D-Printer
LEAD 1010 PLASMA Add-On
LEAD 1010 PLASMA Add-On is a great modification you can do for your LEAD 1010 to convert it into a metal cutting monster machine!
LEAD Lathe
zero z mongrel
long overdue overhaul of 1000 x 1000 machine
Gerber 404 Retrofit
Not sure if the Blackbox X32 is the right option here, just looking for guidance.
Rotary Axis OX Derivitive
A Rotary Axis CNC router based on the OX CNC Router
Dragon Plasma cutter
Build Author Scott Drake Views 14069
1500x1000 CNC Router
Build Author OpenBuilds Views 17481
BlackBox X32
The next level of CNC motion control solutions. Packed with advanced new features and built on the reliability of the proven BlackBox system
2 GANTRY CNC HOTWIRE MACHINE
A 2 independent gantry affordable hotwire machine.
Build Author jaron kennell Views 4062
Rezo 1390 100W CO2 Laser
Sphinx 66
Build Author Neil Rosenberg Views 35091
Build Author Retsaj Views 51283
Build Author Michael.M Views 35459
7050 Sphinx
My Lead 1010
C-beam Machine - Modesty
Build Author Joe Young Views 10933
Rack and Pinion (Death to Belts)
Low profile rack and pinion linear actuator design
Build Author Quentin Karmark Views 5511
Laguna Swift 4X4 CNC mill retrofitted with OpenBuilds
Used Laguna Swift 4X4 CNC mill with Water-cooled Spindle and RichAuto serial pendant retrofitted with OpenBuilds/Blackbox/Interface
Techsoft Roland TS-30 rebuild
Openbuilds 4x8 cnc
Build Author Mark Carew Views 18699
Build Author OpenBuilds Views 22369
INTERFACE CNC Touch Control System
Super cool standalone Human-Machine Interface for controlling your CNC machines!
Build Author StrictlyScale Views 6474
Lead1010 Build with Enclosure
First time CNC builder puts together a Lead1010 machine.
Build Author EvanH Views 864
Build Author Keith Davis Views 19623
Vulcan MAX
5'x10' CNC Plasma/Mill Table
Plasma Mill CNC
Build Author Bob Darrow Views 6136
BA3DP
modifying ACRO
"Hirata scrap find" CNC
First CNC and first attempt at building one also, so yeah... good luck to me!
Z Floating Head
KRE CO2 2x4 Laser
Large Format CO2 Laser Cutter
Build Author Mark Carew Views 73402
Build Author Mark Carew Views 57252
Build Author Kyo Views 22015
Sphinx 55
Build Author cdsmith12 Views 24283
Build Author openhardwarecoza Views 71164
openBuilds FreeBURN-1 V-slot CO2 Laser (60-100w)
DIY Lasercutter: Budget orientated, medium sized (60-100w), safety first, based on Lasersaur software toolchain
Build Author Spark Concepts Views 13179
CNC xPRO V4
Take your build to the next level with the CNC xPRO V4!
cnc back stop for brake press
back stop build
Build Author Troy Proffitt Views 23589
Hydraulic lifting table
Build Author Mark Carew Views 116902
C-Beam™ Linear Actuator
My large machine 48 X 48
Build Author Frank Del Favero Views 5206
Build Author Mark Carew Views 178317
LEAD CNC 1010 (40" x 40")
Build Author sausagePaws Views 72466
Build Author Ryan Lock Views 122871
WorkBee CNC Machine
Build Author CONUCON Views 2670
3DTwinX Gantry CNC System
Belt driven 3-axis linear system for high precision and low costs. > Threading and linear real cutting needed
Build Author Mark Carew Views 28186
High Z Mod for Lead CNC
LR/BS CNC Router
An easy to source/easy to build, yet quite robust CNC router. This design has not yet be implemented.
Build Author tshilling Views 31556
Build Author Mac6986 Views 15036
Build Author Ryan Lock Views 129004
Ooznest OX CNC Machine
Heavy Metal
Build Author Gerald Klein Views 13227
Reworked Sepcraft 420 CK
Its alive !
Build Author Kyo Views 30107
Sphinx 1050
Salmon Sphinx 1.0
Build Author Suhmanda Views 2001
DIY CNC SPINDLE
CNC SPINDLE FOR DIY ROUTERS AND MILLING MACHINES ITSRS-985 MOTOR HAS MUCH BEFINITS THAN ANY OTHER DC MOTOR IN MARKET
Gauthali V2.0 DIY 3D printer
Build Author alan richard Views 45196
Core-XY Cube
Build Author Rob Taylor Views 15563
M4: 1510SS Heavy Mk.I
Build Author Keith Davis Views 32270
OneZ i3
TrueUp Bold
Pneumatic cnc cutter with festo drive
CNC Glass cutter
CNC Cutter Knife
CNC knife cutter with loline blades
CNC Linear Slide for DIY project
Low cost cnc linear drive for making any xyz cnc structure
Plasma Table 006
Build Author Mark Carew Views 252232
C-Beam® Machine - Plate Maker
Build Author Mark Carew Views 13235
C-Beam XLarge X/Y Table
Build Author Ryan155 Views 8551
RIGCNC
I made a mill from first principles because I didn't like any of the ones that were out there, More info can be found on the website RigCNC.com
Build Author OpenBuilds Views 12271
C-Beam® Tension XL Linear Actuator
Build Author that-jim Views 6931
Z-Axis Upgrade For My Sphinx
Build Author that-jim Views 41156
Build Author MattR Views 16574
Build Author Damian V-SLOT Poland Views 1802
LEGO BOX
Build Author OpenBuilds Views 18284
OpenBuilds Table Series
The OpenBuilds Table Series offers a modular table structure that grows with your needs.
My ACRO Build
An ACRO laser put together with some repurposed and some new parts.
Build Author Mark Carew Views 68199
OpenBuilds Workbee 1010 (40" x 40")
The OpenBuilds WorkBee 1010 - 1000x1000 Lead Screw Driven CNC Machine
A Rolling Plotter
Project Completed.
Build Author UltiBots Views 34196
UltiBots CB3030 CNC Router
Build Author Yanou Fishel Views 8056
Beefed up Minimill
C-Beam Machine XLarge
A rigid and wide format, plate and carving CNC.
Build Author Sigifredo Cruz Rojas Views 2592
ALl included interface
Build Author 2SIsurf Views 4260
Hotwire cnc Surfboards
Xl 2 axis foam cutter Eps Surfboard blanks Simple open concept but high production machine. Shape 3d case with open builds controller
Simpl3rBot
A framing design for cantilever style printers
Build Author Jason Moore Views 9961
Lead1500 Plasma Table w/THC
Denford CNC Resurrection
Denford CNC Mill Update
Build Author wackocrash5150 Views 17007
45W CO2 Laser Build
