Using 4 C-Beam 500 mm actuators and a xPro V2 controller, the C-Beam Big Mouth has nearly 12" of z axis clearance and travel
C-Beam Big Mouth
Build in 'CNC ROUTER BUILDS' published by Richard Gouge, Jun 27, 2016.
My first build was with the basic C-Beam Build. I soon found the z clearance a little constricting So I added 2 500 mm actuators to support the x axis rail . I also left off the front and back y axis support rails for easy cleaning. I mounted the base of the machine to 1/2" mdf with 10/32 screws and blind nuts.
Jeanalvitre, Sonny Lowe, MaryD and 2 others like this. -
Build Author Richard Gouge, Find all builds by Richard Gouge
For the ability to work on larger itemsInspired by
My first project was the basic C-Beam build
