This is an acros build. I kind of like customizing it. Eventually I want to build star plots with it.
I added wire tracks to hide the wires. (Got the tracks of amazon)
I also wanted the ability to raise / lower the bed so I added 250 mm long 20x20 legs. Tracks didn't fit below the original motors, also eventually i want to put an air bed under the laser to reduce smoke / flames.
I designed and printed one of the leg connectors in fusion 360.
2040x20x20 Leg v7.f3d
However if I do it over again I would end up using the black Cube corner connects OpenBuilds sells. for joining 3 20x20's together. Kind of expensive though.
I added an Z axis from banggood for about 45 dollars. Its wide enough to support both the laser, and a pen holder I got from Eleks for 15 dollars.
The laser is 150 dollar 5 watt laser I got from banggod for 150.
Seems to work well enough. Still calibrating it. There is a little button on the ttl controller board that puts out a very low pwm to the laser. Focus the dot until it looks good, then run the laser across the X axis on a ramp.
Find out where the dot is the smallest and set the Z height to that.
I ordered some expensive goggles with OD6 protection from survivallaserusa. Link is here.
This laser kind of scares me so im going to be installing 2 side sheets of protective shielding from jtech.
Also I will be cleaning up the wiring to the controller board more, and adding a airbed in the future.
Acros with customizations [WIP]
Build in 'Laser Cutter Builds' published by Sam Price, Jan 27, 2018.
This is a work in progress ACROS build with new legs and wire tracks.
Mark Carew, james poulton and nc3dpw like this. -
Build Author Sam Price, Find all builds by Sam Price
Eventually want to laser cutout star plots
