OpenBuilds has shared a number of very nicely designed of Linear Actuators. All has been based on the "normal" rails and C-Beam.
I have for some weeks worked on a new type of linear actuator based on the 40x40 profile. This profile has a big internal cross shaped opening. It is big enough to have an ACME rod/nut assembly inside, so the design idea is to use this to make a mechanical assembly.
I have focused on making a compact design that hold the footprint of the extrusion and stepper motor.
I have ended up making some 3D Printed parts to hold the stepper motor, bearings and as a guide for the Brass ACME nut inside the rail.
The rod used is Ø15mm aluminum with a wall thickness of 1mm.
In the file section you will find .STL files for the 3D Printed parts. They include all parts needed for the actuator as well as two mounting plates and a guide for drilling four mounting holes in the aluminum rod. A .STEP file is also uploaded.
40x40 V-Slot Rod Type Linear Actuator
Build in 'OTHER BUILDS/PROJECTS' published by Martin.Barfoed, Feb 14, 2020.
A Rod-type Linear Actuator based on the 40x40 V-slot profile
Cameleer, Rob Blaauw and Mark Carew like this. -
Build Author Martin.Barfoed, Find all builds by Martin.Barfoed
