      My project was to build a smaller and more precise mill for use in making smaller projects and to build it with parts and materials I had on hand except for Steppers, motion controller,and a few screws,bearings and maybe a few pieces of Aluminum
      Now that my slow boat from China has arrived the project is complete except to disassemble and paint the unit. I am using 1/2" Delrin for the "waste" board, that sits on top of the 1/4" 6061 aluminum main table. I am putting .300" holes on a 1.125" spacing so that I can add 1/4" threaded inserts from the bottom side of Delrin, The bridge will be modular and removable from the "Y" lower half . I am using an Acorn Motion Controller instead of Mach3 or Mach4. Centroidcnc has built Motion Controllers for many years and the Acorn is their latest product for the Hobbyist. IMG_0195 [800x600].jpg IMG_0195 [800x600].jpg
        Your BOM will most likely be much different than mine since I had the Rails and slide bearings and the "Z" axis and spindle motor and most all of the aluminum and all of the wiring and connectors.
    I built this to use in my PC projects and small engraving projects
    and to see if I could keep the cost below $400.00 but not sure I did that. Also I wanted the smallest foot print I could build that would also be practical.
    Everyone that I have seen and watched for the past 50 years
    3 425 oz in Steppers Link I bought the steppers from Ebay as a set of 3. double ended
    1 Acorn Motion Controller http://www.centroidcnc.com Link Very powerful medium price Controller comes with it's own Mean Well 24vdc power Supply
    1 36 vdc 11 amps switching power supply http://www.ebay.com Link For Steppers
    2 600 mm lead screws http://www.ebay.com Link My Choice for these screws was , 8mmx1mm for my project
    2 Zero blacklash nuts for 8mmx1 lead screws http://www.ebay.com Link
    4 Leveling legs http://www.ebay.com Link 10mmx1.5 x50mm swivel pads W8R2
