ZANTRY CNC
Discussion in 'CNC Mills/Routers' started by Adam Filipowicz, Apr 30, 2017.
  1. Adam Filipowicz
    Adam Filipowicz Veteran
    Adam Filipowicz published a new build:
  2. Adam Filipowicz
    Looking forward to hearing some feedback on this idea.
    Current photo is a quick rough to get the idea out of my head
    doesnt include wheels and many other small parts.
    once I flesh this out I will redo a proper cad drawing.
    I like that so far this is all Openbuilds parts. No custom Plates
    What I dont like is 5 Steppers
    #2 Adam Filipowicz, Apr 30, 2017
  3. Julius
    Julius Veteran
    No need for all those corner brackets. Just bolt into T nuts through the plate that then connects to the threaded rod.
  4. Rick 2.0
    You might consider moving the X-axis to the back side of the vertical risers. This will center the mass of the router better over the Y-axis wheels.
  5. GrayUK
    GrayUK Master
    As Rick said, with the spindle/router out on a limb like that, you are putting a lot of stress onto the wrong side of the gantry.
    Gray
  6. Adam Filipowicz
    Thanks for the feedback!
    here is an updated version
  7. Rick 2.0
    Looks good. :thumbsup:
    If you're dropping back to single gantry plates on the Z-axis (which should more than sufficient), you might consider using the C-Beam™ Gantry Plate - Double Wide plates instead, connecting the X beam to the upper half of the plates (leaving the lower half operating in what is functionally dead space along the sides of the Y axis). This will give you another 45mm to work with in both the X and Z directions and make the frame a bit stiffer due to the increased vertical spread of the wheels. I would also suggest the 8 wheel configuration on these plates for additional rigidity.
    Rick.
    MaryD likes this.
  8. Adam Filipowicz
    XL gantry plate can do 6 outer and 4 inner mini wheels correct?
    Double gantry 8 mini inner
    I would have though XL would be stiffer.
  9. Rick 2.0
    No, the XL plate doesn't accept inner wheels. So the difference here is the leverage provided by the roughly 145mm vertical spread of the double gantry wheels versus the 100mm vertical spread of the wheels on the XL plate. This will help with both the racking of the frame and resisting the torsional load induced on the X axis by the spindle. (It doesn't help the X axis itself, merely the way the force is transmitted into the Z axis.)
    Adam Filipowicz likes this.
  10. Adam Filipowicz
    Good to know! Thanks!
  11. Adam Filipowicz
    Revised again switched to Double Wide Gantry plates for Z and Y
    again,. please ignore some of the obvious errors in the rendering. (, random wheels, screws, acme being too short lol) :)
    Zantry CNC May v1 v7 Under.jpg Zantry CNC May v1 v7 Back.jpg Zantry CNC May v1 v7 front.jpg
  12. Kevon Ritter
    Kevon Ritter Veteran
    I was just thinking about something like this today too! Then I said no since it would be another axis that could become shifted.
    But your z travel is going to very poor if you used the bottom on the double c beam plate.
  13. Kevin Henning
    Kevin Henning Well-Known
    I like the idea of this... Julius, your suggestion of mounting the plate directly to the C-Beam using T-nuts (and then getting rid of the cast corners) is also something I had noticed... Do you know if the head of a low profile screw will fit in the gap between the plate and the C-Beam with the threaded rod, or would it be necessary to countersink the screws?
    Adam, if you don't want to run 5 steppers it may be possible to increase the height of the base and then have the Y and/or Z axes driven from underneath using the standoff plates and some GT-3 belt pulleys... It would work in wood, etc, in the same way as the Ox, but I don't know how well it would handle working in aluminum if that was a target material for you.
  • About Us
  • Like us on Facebook
    Donate to FairShare!
