YAPCNC (Yet Another Poor's Man CNC)
Discussion in 'CNC Mills/Routers' started by sergien, Jul 8, 2018.
  1. sergien
    sergien New
    sergien published a new build:
    As this is just a temporary build with the intent of using it to cut permanent metal plates I would suggest bringing the X-axis down as close to the table as possible. This will increase the stiffness of the machine and improve its ability to cut metal. Other suggestions would include moving the Y-axis rails as high as possible (again to increase stiffness) and installing some glued and screwed solid wood inside corner blocks between the uprights and the X-axis beams to increase the strength of this connection.
    Happy building. Keep us updated.
    MaryD and sergien like this.
  3. Andreas Bockert
    Andreas Bockert Well-Known
    What are you planning to use for movement? Belt or screws?
    As Rick mentioned, you should to add some 90 blocks to the inside corners to increase stiffness. MDF/Particle board doesn't have great holding power for screws so it's likely that the screws crumble up the threads. So in addition to 90-blocks I would suggest using nut and bolts that go through both pieces to tighten them down.
    Those DRV8825 are more capable than you would expect. I ran my machine using 8825 with an old computer fan cooling them and had no problems.
    Good luck, it will be interesting to see how this progresses!
    Cheers,
    Andreas
  4. JustinTime
    JustinTime Veteran
    You could do as Rick suggested, lowering the y axis, or you could leave the two upright plates as long as they are but add a strip of 3" (or there about) particle board on each side of each of the plates creating an I beam. It will stiffen them up a lot!
    What Andreas said about the screw not holding well in particle board is correct. You can change it by either pre-drilling the hole and pouring some CA glue into the hole or screwing the screw in, taking it out, pouring some CA glue into the hole and after the glue dried screw the screw back in.
    sergien likes this.
  5. sergien
    sergien New
    Hi!
    First of all thanks for your improvement ideas. I really appreciate the contributions.
    Regarding the holding of the screws my idea is to use T-Nuts on the opposite side of the board (and washers on the screw side). That should hold the screws in place and overcome the problem of the holding power of the particle board.
    All the structure is to be reinforced with some strips to stiffen it up ... the actual photographs are from the initial "proof-of-concept" to see if my measurements hold the "reality" test.
    Now I'm waiting for the rest of pieces to arrive. I don't want to make more drills till the actual piece can be measured and see if it match the specifications.
    Cheers!
  6. MaryD
    MaryD OpenBuilds Team
    Not sure if this will help but this steel tee nut will add threads to particle board
    sergien likes this.
  7. sergien
    sergien New
    That is exactly the t-nuts I'm refering t .. I've used them on other projects and they work nicely.
  8. Rick 2.0
    Yes, this will help reduce sidesway of the gantry frame but it won't reduce deflection of the cutting bit caused by unnecessary Z-axis length.
    sergien likes this.
  9. Giarc
    Since all your plates are square, you could also just cut them out of aluminum and skip the temporary step. It is relatively easy if you have access to a table or chop saw. That is what I did. It was a fun challenge. Lead Screw Driven Ox Derivative (850x1500)
  10. sergien
    sergien New
    That's the problem ...
    The first reason is I've no access to a table saw (only commercial providers) so the cutting will be expensive.
    The second is I want to make sure everything works before going to the metal phase.
    Cheers!
  11. Giarc
    Ok. I just assumed you had one since your wooden parts looked nicely cut.
  12. sergien
    sergien New
    Yup, but the provider cuts only wood on that machine ... as soon as you say metal, they say "Mmmm ... then our CNC should be used ... cost is 100€/hour ... minimum time is 1 hour and do not include materials" ...
    There is no rest for the wicked!
  13. Gary Caruso
    Sergien,
    You could easily use wide bar stock for these plates and cut with a hacksaw, or jigsaw :)
    That said, I do think there is a way to make this work out of Wood.. and I agree to lower the gantry for stiffness..
    Gary
    sergien likes this.
  14. GeoffH
    GeoffH Journeyman
    I see that you have received a lot of concerns about the gantry height, but from my point of view, larger z travel is very useful, of course unless you only want to cut flat plates. So I would carry on trying to stiffen the supports using your nouse! Good luck completing the project.
