X-carve upgrade
Discussion in 'CNC Mills/Routers' started by Joe Garritano, Aug 23, 2016.
  1. Joe Garritano
    Joe Garritano Well-Known
    Joe Garritano published a new build:
    Mike Piechowski and MaryD like this.
  2. Mike Piechowski
    Mike Piechowski Journeyman
    Nice work!
    Are the SVGs in inches? My CAM package pulls the file in OK, but I think I have the dimensions messed up.
  3. Joe Garritano
    Hi Mike - yes, I have an annoying habit of designing in imperial units. I'm in counseling for it.
  4. Mike Piechowski
    At least you're using inches, not pixels... I can work with inches.
    Thanks for the clarification, and thanks for sharing your efforts.
  5. slm222
    slm222 Well-Known
    how has tying the carriage wheels together with the threaded rod helped the stability? i find my x-carve has some front to back deflection
  6. Joe Garritano
    It helps with front to back deflection. :) Seriously, though, you can imagine how much easier it would be to move 8 independent v wheels (torsion), because of the lever arm effect (from the screw head, through the carriage, past the washer, through the vwheel to the nut. If there was no carriage, you could probably put your finger on the nut and with enough force, move that screw, no matter how tight you had it. However, if that screw continues all the way through, so it is supported on both ends, and is potentially even tensioned slightly by the nuts holding both wheels... suffice to say it is a worthy mod for the x-carve. I bought longer m5 threaded rod, got each one adjusted, and cut off the long end. No big deal. The inside lock nut holding one of the vwheels ends up backwards (too hard to thread on starting with the nylon locking part), so I use a washer to disperse that force. An engineer might cringe at that but it works sufficiently for this application.
    GrayUK and slm222 like this.
  7. slm222
    slm222 Well-Known
    Instead of a threaded rod I was thinking of getting 4 m5x90mm socket head screws. And cut off the extra length.
  8. slm222
    slm222 Well-Known
    did you document the process of installing that z-axis?
  • About Us
  • Like us on Facebook
    Donate to FairShare!
