WorkBee Lead 1010, Reduced Foorprint, Nema17
Discussion in 'CNC Mills/Routers' started by KronBjorn, Jun 16, 2019.
  1. KronBjorn
    KronBjorn New
    KronBjorn published a new build:
  2. Mark Carew
    Great looking Build ideas @KronBjorn
    Why the reduced footprint and nema 17's? What are you planing to use this machine for?
    Thank you for sharing.
  3. KronBjorn
    KronBjorn New
    I have limited space in my shop, so I would rather have 10cm extra cutting depth and witdh, than deadspace around the CNC. And there is plenty of space inside the envelope. I also think it could be worth considering adapting the endplates to accomodate this position ?
    I thought that if a Nema23 is strong enough for the belt driven workbee, then something less powerfull should work on the lead screw based, due to the gearing. It was also what I had lying around from my MPCNC, and they are much cheaper :)
    I will soon know if they are too weak or slow with the extra belt gear.
    Thank you for the interest,
    Len4ik79 and MaryD like this.
