Wires
Discussion in 'CNC Mills/Routers' started by eleethesontai, Aug 9, 2017.
  1. eleethesontai
    so almost done with my diy cnc at the electronics. Problem is I didn't consider wires when designing. The stepper motoro wires are to short and the power Supply doesn't even have wires. So stupid question but what kind of wires do I need to get?
  2. Hisha
    Hisha Veteran
    This is what I used when I was hooking up from my drivers to some NEMA 23 steppers. Wire on Amazon.
  3. eleethesontai
    Thanks and this will work for the power Supply as well? Plus my spindle?
  4. Hisha
    Hisha Veteran
    I'm using a Bosch Colt so I can't say for a spindle, but if you look at my build you will see I used this wire all over in my controller.
  5. Gary Caruso
    Gary Caruso Veteran
    shielded wire is a good idea for steppers
    Amazon 50 feet
    you can use this for the spindle, or better is get some shielded 2 conductor for that, the AWG size depends on the power spindle
  6. eleethesontai
    I have 269oz 3.2 amp steppers and a 400 watt quiet cut spindle from smw3d with the spindle controller. And 48v 400 watt power supplies for each.
