Vulcan MAX
Discussion in '3D printers' started by Keith Davis, Jul 3, 2020.
  1. Keith Davis
    Keith Davis Veteran
    Keith Davis published a new build:
  2. JustinTime
    JustinTime Veteran
    Keith, clicking on any of the links in the build section downloads the same zip file. Is that by design?
  3. Keith Davis
    Keith Davis Veteran
    Certainly NOT by design! They've been fixed, journeyman. THANKS!
  4. Joseph Helmstetter Jr
  5. Keith Davis
    Keith Davis Veteran
  6. Joseph Helmstetter Jr
    Hey Keith, I noticed that the X axis pulley mount STL file is mirrored from the object in the SKP file. I tried exporting it to a STL from the SKP file and it came out reversed as well.
    [​IMG][​IMG]
  7. Joseph Helmstetter Jr
    I was able to correct the orientation.
  8. Keith Davis
    Keith Davis Veteran
  9. Samsamit
    Samsamit New
    I think there is some models missing? Hi, Im new to custom 3d printing and i decided to start with your model. I have ordered almost all parts and now i need to get thease printed parts. I dont have a program to open skp files so stl is all i have.
  10. JustinTime
    JustinTime Veteran
    The .skp files are SketchUp files. You can find SketchUp online for free. Get an older version, like 2017 or earlier. Google it.
  11. Peter Van Der Walt
    Newer versions of Fusion360 happily imports Sketchup files too
  12. JustinTime
    JustinTime Veteran
    I haven't tried it recently but the last time I tried it imported it like it does with imported .stl files. It imported it in triangles, which is a pain to work on subsequently.
  13. Samsamit
    Samsamit New
    Hi! Great job with the step by step quide! Im still having some issues regarding the .stl files. I think you are missing the Y axis top pieces that holds the screw.
  14. Keith Davis
    Keith Davis Veteran
    Which screw? Could you reference it by STEP in the assembly guide?
    I think you are referring to the 2 top Z axis brackets that hold the Z axis screws, i just added them to the x-axis-loom-anchors-zmotor-front-tops.stl file in the vulcan-max-stls.zip
    #14 Keith Davis, Aug 27, 2020
  15. Samsamit
    Samsamit New
    Yes Keith, im talking about the part in step 32, Z Screw Top Anchor. I have also noticed that some parts needs to be mirrored but when they come in same stl its not possible for example for cura to mirror them. What should i do for this? Also some of the slts are too big for my printer or i would like to print them separately for lower time.
  16. Keith Davis
    Keith Davis Veteran
    I plan on making a new set of STL files tomorrow. I use a 200x300 bed and try to fit enough for an overnight print - 12 to 16 hours worth. Slice3r allows you to split an stl into parts , then delete what you don't want and save to a new stl. I just figured all gcode generators had that capability, I'll instead make a set of each part (pairs).
  17. Samsamit
    Samsamit New
    Nice! Ill be waiting for that. I will have all the parts within two weeks and i need to design a frame holder for titan aero combo. After that hopefully i will be able to setup this whole thing and see what it is capable of. Im also thinking about recording this assembly and putting it to YouTube.
  18. Keith Davis
    Keith Davis Veteran
    That sounds nice. Let me know when you have that done and I'll add a like to it on the build page with credit to you.
  19. Keith Davis
    Keith Davis Veteran
  20. Samsamit
    Samsamit New
    Many thanks! Btw. amazing job Keith keep doing what you're doing.
    EDIT: EDIT: There is a skp zip which contains the separately but i cant print those.
    #20 Samsamit, Sep 1, 2020
  21. Keith Davis
    Keith Davis Veteran
    I always publish a separate zip containing the individual SKP files. plus another zip with the SKP assembled file just for those who may want to modify the design with Sketchup.Make.
  22. WilberMaker
    Samsamit, when you get a mount design for the titan aero I would like a copy if you would. Just starting a build and that would speed me up some. THX
  23. Samsamit
    Samsamit New
    Ohh i can do that but i have newer done any designing so im wont guarantee any good results :D I want to design a mount with two fans and a place for 3d touch. And about the video... I dont have the time to make it :s Sorry Keith
  24. Samsamit
    Samsamit New
    Ok so i bought a T8 lead screw for this project and the mounts didn't work with it so i made new ones. they can be found here if someone wants to use them -> T8 lead screw mounts by samsamit
    Alse for the TitanAero i came up with this type of mount. I ordered only big wheels for v-slot so this is what im using now. Titan Aero Mount by samsamit
    IM still desinging a working part cooling solution for titan aero but its pretty hard. I want to use 2x40mm noctua coolers so there isn't any ready solutions.
  25. WilberMaker
    Samsamit that it looking great can’t tell a lot on the phone but look forward to seeing more detail when I get home. Have you thought of any provisions for a inductive probe?
    Good work!
    Sam
  26. Samsamit
    Samsamit New
    Well im using blTouch and found a cool mount that goes between the hotend fan and cooling block. For inductive mount it should be fairly easy to add a slot to the whole mount. For my cooling solution i wanted to have the sides open. There is this filament quider i made in the mount. not sure if it helps but i should be able tto put this bowden tube connector there is i need to.
  27. Keith Davis
    Keith Davis Veteran
    I am curious about you guy's desire to use an inductive probe or blTouch. Perhaps you have missed the point of using a single Z axis motor and timing belt - bed leveling is something you do during construction. Once done, the bed and extruder will remain level for the life of the printer.
  28. Samsamit
    Samsamit New
    **** Keith, you are absolutely right :D i didnt even think about it. all the tutorials were talking about auto bed leveling and i was like "That's what i absolutely need in my printer". But now that i have one im going to use it and test it. im not trusting my construction work that mutch :D
  29. Keith Davis
    Keith Davis Veteran
    *****Using an auto-level will have NO leveling effect since both Z axis screws are locked in sync with each other.*****
    The only thing that can cause a printer to get out of level is two independent Z axis motors using microstepping. That is because microstepping was not developed for accuracy and is inherently up to 70% inaccurate. If you use an auto-level on a single motor Z axis it will force the printer to increase that inaccuracy exponentially, but instead of having an effect on leveling, it will show up in layer height inaccuracy, and decrease layer bonding on taller print objects.
    When you've finished construction, lower extruder nozzle down to the center of the build surface. Place a sheet of printer paper between the nozzle and build surface. Adjust Z axis height so paper barely slides under nozzle. Loosen the set screws on both Z axis screw pulleys. Move nozzle to let and right, rotating each Z screw to get equal drag on paper. Tighten set screws. Move nozzle to each corner and adjust corner screws to get equal drag on paper. The printer is then level and will remain so for the life of the printer.
    Samsamit likes this.
  30. JustinTime
    JustinTime Veteran
    That is correct but I think if you have only one 3d printer and you use different material for printing you can use the probe to adjust the extruder height from the bed. I use a different glass for ABS and a different for PLA. The ABS has Kapton tape on it and the PLA has blue painters masking. I have to adjust my Z height every time I change the material. With a probe it will be done automatically.
