Vic Aussie Ox
Discussion in 'CNC Mills/Routers' started by John Eriksson, Jul 28, 2015.
  1. John Eriksson
    John Eriksson published a new build:
  2. motopreserve
    motopreserve Well-Known
    Hey John. Looks like it's going to be a nice build. I'm in he process of building my first ever CNC router/mill.
    The acme screws need a bit of sanding to fit the bearing on the ends. @Mark Carew shows his process in the video for the C-Beam Plate Machine build. Basically you can lightly chuck the acme screw in your drill and spin it while holding some finer grit paper on the last 2 inches of each side. Mark suggested 220 grit.
    I just did it a bit at a time to ensure I didn't remove too much material and make the fit too loose.
    Looking forward to seeing your progress.
