Vacuum laser table
Discussion in 'Laser Cutters' started by Cody Kesler, Jun 16, 2019.
  1. Cody Kesler
    Cody Kesler published a new build:
  2. GrayUK
    Cool looking build. :thumbsup:
    I wonder if the vacuum will deal with, the smoke and burn smells created by the laser/plasma, as well as the hold-down properties? :rolleyes:
  3. Mark Carew
    Hi @Cody Kesler Great to see you here sharing your build on OpenBuilds! Thank you.
    So for setting up your machine size you only need to set the OpenBuilds CONTROL software to custom machine type and then you can set up the parameters like bed size there for your machine.
    Hope this helps, all the best with your build my friend. :thumbsup:
