The Nguni - an OX variant
Discussion in 'CNC Mills/Routers' started by David the swarfer, Oct 7, 2015.
  1. David the swarfer
    David the swarfer published a new build:
    "....a vertical vice..."? I'm hoping you mean "vise" as there are certain things you shouldn't do on an Ox. ;)
  3. Mark Carew
    Looking forward the Nguni OX build David! :thumbsup:
  4. Mark Carew
    I see the plates worked up in SketchUcam :) Very cool
  5. killRMODZ
    killRMODZ New
    This would be an excellent upgrade for those wanting a slightly larger spindle with carriage plates that allow beefier 80/20 extrusions for y axis travel to support the heavier Z. I might be interested in some aluminum versions... soon!
  6. Mark Carew
    Alright your back on it. Love the aluminum anti-backlash nut block David :thumbsup:
  7. David the swarfer
    Strangely the banggood leadscrew which that brass nut came with is a slightly different size to the one you sent, even though both are M8X8 4 start. So, that nut is time wasted and I am using your nylon one, much smoother really.
    Last night quick test run....
  8. Abird
    Abird New
    Hi David,
    I just wanted to check, how far have you progressed with the Nguni build.
    Will you be using NEMA 17 or 23 stepper motors for the X and Y axis.
    Abid
  9. David the swarfer
    Hi @Abird
    Not much going on, been too busy on other stuff >-:
    I have Nema23's for everything though I do wonder if that will make the Z a bit heavier than it needs to be.
    Heavier = slower after all.
  10. Abird
    Abird New
    Thanks,
    I may have to rebuild my chassis and make it smaller.
    I just have the one NEMA 17 from Netram and plan on using threaded rod for the drive mechanism.
    My project has been on hold for over 18 months. I'm trying to keep it as cheap as possible.
  11. David the swarfer
    I need to actually build a table to put it onto, but before that I need to make a place for the table, which means a whole list of other things have to be done first to allow that to happen. a bit overwhelming....
  12. GrayUK
    I know that situation well David. I have spent most of my life saying; "Before I do that, I gotta do that, but first I gotta do that, but not before I do that though",
    and so it goes on and on and on. :banghead: :D
    Gray
