Tap size or longer self tapping screw
Discussion in '3D printers' started by Josh Hulgan, Dec 14, 2016.
  1. Josh Hulgan
  2. Christian Setla
    Christian Setla Journeyman
    The M5 Drill Tap should be fine, I just used a regular 5mm HSS tap when I threaded mine.
    You WILL want to stop by any local machine shop supplier and pick up a small container of RapidTap or some such lubricant for aluminum tapping... Without it, it was awful and I almost broke the tap a couple of times when it got stuck. A couple drops of RapidTap and it's super easy.
  3. Mike Piechowski
    Mike Piechowski Journeyman
    The drill tap should work. I tend to use mine on plates and thinner stock. I use a spiral point M5 tap to tap my extrusion and thicker plates. I also use it in a cordless impact driver. A few drops of tap-magic per hole and tapping is super quick.
