Strong? CNC
Discussion in 'CNC Mills/Routers' started by PatrickB, Aug 29, 2017.
  1. PatrickB
    PatrickB Well-Known
    PatrickB published a new build:
    Hi! Please leave your thoughts about this build!
    swohnrade likes this.
  2. Rocrat
    Rocrat Well-Known
    Patrick , nice design , keep going . Linear rails are always more accurate and can easily be added to your Z axis if using a Cbeam .
    Another thought here , your Yaxis lead screws are out in the open waiting to take an impact from something , you could move them to the other side of the Y plates inline with the linear rails , it will also put the load factor in line with the linear rails as opposed to putting a torque moment on it if off axis with the rails .
    Regards Rat
  3. Rick 2.0
    Overall nice design. The height of the X-axis will have a negative impact on stiffness. You might consider bringing it down or increasing the thickness of the side plates to reduce the lateral flexibility. Side shields might also be a good idea to keep debris out of the Y-axis screws.
    I've been waiting for someone to give the square steel rail inserts a try. Please keep us updated on progress. :thumbsup:
  4. PatrickB
    PatrickB Well-Known
    Check the updates in my build section!
  5. Rocrat
    Rocrat Well-Known
    Patrick , that looks pretty solid and far more accurate then steel on aluminum . I believe you still should move the ball screw to the outside of your side plates in line with your linears to stop any level arm movement when under load . Like the new design with the plexiglass sides .
    Keep it rolling
  6. Julius
    Julius Veteran
  7. Gary Caruso
    Gary Caruso Veteran
    great idea! never thought of just adding square stock to the v-rail. One thing i would suggest is that you probably don't need to double up the wheels like we do with the plastic ones.
    I've seen very large cnc machines use steel V-wheels and have only one at each corner and no problems.. steel on steel is much more firm than aluminum to plastic, but either way it wont hurt.
