RSW's C-Beam Build
Discussion in 'CNC Mills/Routers' started by RSW, Jan 3, 2017.
  1. RSW
    RSW New
    RSW published a new build:
    Spark Concepts and GrayUK like this.
  2. Mark Carew
    So many great mods and upgrades on this C-Beam Machine Build, really well done job! @RSW thanks for taking the time to share
    Mark
    RSW likes this.
  3. Spark Concepts
    Spark Concepts Journeyman
    Very nice build! Not sure if you have used the laser much, but how do you find the speed using the screw drive? I was debating about adding on to our Cbeam or making a dedicated belt driven laser... Thanks for sharing!
  4. RSW
    RSW New
    Hey Michael,
    I have not used the laser on the C-Beam yet, but did use it on my old very crud screw drive CNC with pretty good results. I will be trying it on the C-Beam in the next few days and will post some results.
  5. RSW
    RSW New
    I did a quick test with the laser on the C-Beam. Still have a lot of configuration to do, but it works.
    GrayUK likes this.
  6. dmon123
    dmon123 New
    Hi RSW. Super build. I have been struggling with getting the Y axis range to be a bit bigger. After reading a lot and seeing your build, I get it. Could you explain to me how you figure out / measure the position of the outer wheels which stabilize the Y plate? I would love to add this to my c-beam... Would you by any chance share your modified plate design? With many thanks, David
