Reference sensor for CNC Tools
Discussion in 'CNC Mills/Routers' started by AK-Creation, Oct 31, 2016.
  1. AK-Creation
    AK-Creation Well-Known
    AK-Creation published a new build:
    GrayUK likes this.
  2. Mark Carew
    Wow this is great @AK-Creation ! Thank you for the share
  3. MaryD
    MaryD OpenBuilds Team
    Awesome!
  4. AK-Creation
    Hello Mark, Hello Mary,
    thanks for your comment! :)
  5. AK-Creation
    Hi Justin Time,
    it is very simple.
    The G28 Code is for Homing.
    When you use "G28 X0 Y0" - The Homing are only by the X and Y Axis. By reaching the limit switch the X and Y Axis position is "0".
    When you use "G28 Z" - The Homing are only by the Z Axis. And by reaching the Z limit switch ist the position "0".
    When you use "G28 Z26" (26 ist the complet high from the Sensor) - The Homing are only by the Z Axis. And by tiggerd the Sensor, the Z Homing position is set to "26 mm".
    My Cam Software (Estlcam) calculate the CNC Program from the "0" - Point to minus (the Hole -3 mm deep).
    The CNC Machine drive fast (F1500) to the "0,5 mm" Z Position and begin to mill the Hole (-3 mm deep).
    I hope I could help you.
    JustinTime and GrayUK like this.
  6. Anthony Bolgar
    Anthony Bolgar Journeyman
    Nicely done!
  7. AK-Creation
