Portable self-contained Lead 1010 table
Discussion in 'CNC Mills/Routers' started by Frank Del Favero, Jul 18, 2022.
  1. Frank Del Favero
    Frank Del Favero published a new build:
  2. Rink
    Rink Well-Known
    Great table. I've been dreading the cost of building a table fully from plywood...at today's ridiculous lumber prices. 2x4's and MDF, great cost-effective idea.
    So...how do you like the LEAD 1010? Any challenges in the build process? Have you calibrated, trammed, etc.?
    Thx, rink.
  3. Mark Carew
  4. Giarc
    Very nicely done!
  5. Frank Del Favero
    Thanks for the kind words. Yeah, when I purchased the materials I was shocked by the prices. Fortunately, prices have begun to slowly drop. Other than building the LEAD 1010 and changing out the 250 mm extrusions on the Z axis and replacing them with 300 mm pieces, I haven’t done anything else to the machine. This will add 50 mm to my Z height. I am going to run a project today and carefully examine it to determine if adjustments will be necessary.
  6. JayJ
    JayJ New
    Do you buy chance have any plans?
  7. Frank Del Favero
    Plans will vary based in the size of the table you want to build. 4’x4’ is the perfect size for the Lead 1010. Traditional table height is 36” the length of the 2x4 table legs is 36” minus the thickness of the table top and the height of the casters you choose to use. For a video on how to build the table go to: It is one of many informative videos on the Fix this Build that channel. Good luck with your work table!
    #7 Frank Del Favero, Aug 23, 2022
  8. tonkajeep34
    Thanks for posting this, I liked it so much when i was looking at redoing my setup I made the same thing. Just instead of drawers made a place for my Acro Laser to sit.
    What feed do you have under the 1010 that's hold it off the table?
  9. Frank Del Favero
    You can purchase the rubber feet from Amazon at: 8 Large Square Rubber Feet Foot Bumpers w/Stainless Screws - .590 H X 1.500 W - Made in USA - Heavy Duty, Non Marking for Furniture, Tables, Chairs, Desks, Benches, Sofas, Chests, & Other Items. Amazon.com
    Nice table by the way. I have the Opt Laser attached to the side of my router. Works great. Also just completed the High Z Mod. I will post pictures soon.
  10. tonkajeep34
    Thanks for the link on the feet, those look like they’d work well.
    I’ve thought about just moving the laser to the 1010 and just have a single machine, but it’s handy to have both so can’t make myself do it. ;)
