Another OX, but this one is MINE :-)
Discussion in 'CNC Mills/Routers' started by Trunkmonky, Aug 19, 2017.
  1. Trunkmonky
  2. Tim Curtis
    Looking good so far. Did you print the parts out of PEGT or ABS?
  3. tru168
    tru168 New
    nice ! I don't know if 3D printed parts can really perform well, can't wait to see for your result !
  4. Trunkmonky
    Thanks! The pieces were printed in ABS. The original idea was to have the router build its own replacement parts, but my printers quality isn't what I had hoped and I will be switching to steel for the X axis when I get the chance. I should be able to use the printed Y and Z axis plates for a few test cuts at very least.
    tru168 likes this.
  5. Savvas
    Savvas New
    It's great to see CNC machines being built with parts made on 3D printers. :)
  6. ihu
    ihu New
    Hey Trunkmonky, Thanks for sharing the project.
    The cutting looks good, but different with the ones from the origin design. Is that the modification for using 3D printed parts?
  7. Tracy Ranson
    Tracy Ranson Well-Known
    Where can I get some of the steel plasma cut parts?
  8. Trunkmonky
    I had them made by a local technical college student who needed a project.
  9. Trunkmonky
    They ended up being closer to the original oozest plates than those for the printed version, however I went with a thinner gauge steel than if they were made from aluminum or acetal/acrylic
    Nice build!
