OX-Metal CNC Router Mill
Discussion in 'CNC Mills/Routers' started by Schematix, Jul 6, 2016.
  1. Schematix
    Schematix Well-Known
    Schematix published a new build:
    Tyson312, bob_col, GrayUK and 2 others like this.
  2. Mark Carew
    Nice work on your Build videos and OX mods @Schematix thank you for sharing this! :thumbsup:
  3. Schematix
    Thanks very much @Mark Carew Nice to get the original maker of the OX 'stamp of approval' :thumbsup:
    scotthz, Bwilly56 and Mark Carew like this.
  4. Mark Carew
    I thank you sir but I can not take credit as so many here in the OpenBuilds community have helped to make the OX what it is today. :thumbsup:
    Schematix likes this.
  5. smg
    smg New
    What would you say the current cost of the OX Metal, which looks very cool by the way would work out too?
  6. GrayUK
    Thanks for that very nice, and informative video. :D
    Nice machine. :thumbsup:
    Gray
  7. Schematix
    My machine cost around $1500USD but that includes shipping to NZ which isn't cheap. So if you live in the USA you'll save a bit off that price!
  8. Peter Eastwell
    Since your in NZ can I recommend my Openbuilds parts supplier CNC kits
    I like what you have done with the OX and the vids are always a great personal touch
  9. Schematix
    Yeah no problem, In fact I bought some components from CNCKITS for this very build myself! ;)
  10. NLucier
    NLucier New
    Is there a list of files for the 3D Printed pieces that were made for the build?
  11. pitzerwm
    pitzerwm New
    Great videos. I have a openbuild machine and the builder didn't add the limit switches. I've watched your videos on this and have a couple of questions. To get the GRBL to know that the switches are installed, and react correctly when hitting one, do you JUST change $21 to 1, or are there other steps? Once the switches are installed and GRBL knows that they are there, is the home feature automatic? I'm using Bcnc with a Raspberry Pi3.
    I was also thinking of using the Makita 701, are you using 1/8" bits also?
    Thanks.
    #11 pitzerwm, Sep 13, 2016
  12. Thunderbird
    I really like this CNC Router and I would be interested in building one to make wakeboards and kiteboards on. In order to do this I would need to make it bigger. The wooden core/blank for a wakeboard is about 160cm x 55cm with the max wakeboard size being cut out being about 144cm x 43cm. After doing a quick google search I noticed that 8mm ACME rod only comes in lengths up to 1m. Is it still possible to build one to the size I want and still use rods and not belts? Im in Australia.
    Nightshade and dean3 like this.
  13. Synths
    Synths New
    Hi Thunderbird,
    You might be able to get ballscrews 150cm long. Take a look at 1604/1605/1610 ballscrews from China on Aliexpress.
    Nightshade likes this.
  14. therubbberboy
    Thanks for posting the video and 3D printing files. I have almost completed my very own OX metal router. I used ABS with 100% infill for printing cause it what I had around. I had a blast building it and probably watched your video 20 times through out the build. Going to take outside and test it soon, waiting for couple of other parts to ship. All the best!
    Bwilly56 and MaryD like this.
  15. CoreCoder
    CoreCoder New
    Does anyone know where to get aluminum extrusion from for this project because openbuilds store is always continuosly out of stock on it?
  16. Ronald van Arkel
    What country are you from?
  17. stokestack
    Hi! like the looks of this build. Can you please tell us which plates we need for the carriage and gantry? The link in the parts list just goes to the general category for OX CNC plates on eBay and none say they're for the carriage.
    Thanks!
    dean3 likes this.
  18. CoreCoder
    CoreCoder New
    US, Phoenix, Arizona.
    JT@BadToTheDrone likes this.
  19. JT@BadToTheDrone
    I'm in the same boat, it appears only 20x80 is available today.
  20. stokestack
    So... nobody knows which plates we'd need for this build?
  21. SugarJ
    SugarJ Well-Known
    They appear to be the standard Ox plates with a couple of additional holes drilled in them. See 3:25 of the complete build video.
    Also all V-Rail appears to be back in stock in the store, although I ordered mine from a Canadian distributor.
  22. stokestack
    Thanks for the info.
  23. Manuel Beer
    Do you guys know wether it is easily possible to upgrade a "normal" ox cnc by ooznest to the "metal" version?
  24. Ryan Lock
    Ryan Lock Veteran
    @Manuel Beer Our OX Kit by default comes with aluminium plates all round.
  25. SBY Bill
    SBY Bill New
    Excellent DIY videos. I am planning on building one. One thing I was interested to know was the accuracy and repeatability of this machine. Any thoughts on that? Also I would like to get the 3D parts, any link for that? Thank you
  26. SugarJ
    SugarJ Well-Known
  27. sravenstein
  28. SugarJ
    SugarJ Well-Known
    Yes they are. Click on the "Thing Files" tab, then download the .rar file and unzip. I just downloaded them again to test it.
  29. sravenstein
    Thx, it seems like that the 4 and 6mm files are the same. What metal plates can I use for this build. Can I download drawings to laser cut the metal parts?
  30. SugarJ
    SugarJ Well-Known
    It uses the standard Ox plates with a couple additional holes drilled in them. Available through the build log "Files and Drawings" tab here: OpenBuilds OX CNC Machine
