Noob 1000Sphinx
Discussion in 'CNC Mills/Routers' started by Joe Downard, Jan 20, 2018.
  1. Joe Downard
    Joe Downard published a new build:
    The 8mm shims you seek are probably the ones included in the mini-V wheel packs.
    BTW, the forum is a much better place to ask questions than facebook. There are 78,000 members here compared to only 6,000 followers on facebook.
    Joe Downard likes this.
  3. Joe Downard
    Hmm.. so the precision shim im looking for goes cbeam end plate, bearing, SHIM, lock collar. So I assume its the only one that will fit over the leadscrew. Thanks Rick. I guess I should have read farther into the instructions.
  4. Rick 2.0
    Sorry, misread your issue. Yes... plate, bearing, 12x8x1 shim, lock collar.
    Mark Carew and Joe Downard like this.
