Enclosure for CBeam / Ox Routers (Lowes / Home Depot Build)
Discussion in 'Concepts and Ideas' started by Peace11uehman, Nov 15, 2015.
  1. Peace11uehman
    ( I am going to keep posting updates as i go along. Scroll down if you want to see the latest additions )
    I have made some progress on an enclosure for my CBeam / future OX type CnC router. I quickly discovered the need for an enclosure shortly after my foam "Hello World" CBeam machine test (in the living room).. So here it what i came up with.
    I sourced all of the parts from Lowes / Home Depot, except for the LED lighting.
    The unit is build on a heavy duty steel frame garage storage rack (72 x 48 X 24 ) which i had to expand to obtain the depth i was looking for. The expansion allowed me to stiffen up the frame using aluminum 1" x 1" square tubing.
    I used Optix acrylic sheets for the windows and doors. The front doors are solid! I originally wanted the doors mounted on rails, however opted against that option due to the space they would require when opened. I used "U notch" aluminum rails that interlocked tightly to create the door frames and mounted them on 30" continuous hinges. I then used clear silicon / adhesive to eliminate any potential vibration rattles etc.
    Just wanted to share some ideas and make a little contribution to the forum since i am a new here. :)
    If people are interested, i can include all the details of the build, however i am pretty sure anyone on these forums could figure out how make something like this based off the images.
    Lowes happens to carry a storage rack with a frame that has hidden shelf slots and is made of steel. That was the key.
      File size:
      164.8 KB
      454
      File size:
      188.2 KB
      381
      File size:
      167.5 KB
      334
      File size:
      169.2 KB
      343
    #1 Peace11uehman, Nov 15, 2015
    Thomas Butson likes this.
  2. Joe Santarsiero
    Joe Santarsiero OB addict
    That's pretty sweet. Is that it's permanent location?
  3. Mark Carew
    That looks great @Peace11uehman this enclosure would make a great build ;)
    Great job
    I don't think the wife would go for that one :)
  4. Joe Santarsiero
    Nope. Maybe if I hung some fake fish in it. lol. Sure beats a fish tank though.
    I plan on enclosing mine someday. I say it's money well spent.
  5. Peace11uehman
    Haha i wish! No, i am already getting hell for it being there..
    #5 Peace11uehman, Nov 16, 2015
  6. Peace11uehman
    Update!
    The enclosure works really well! After some MDF testing, i realized i would need a ventilation / suction system of some sort to help with the dust. I just got back from Home Depot and scored some early Black Friday specials (charmed the lady a bit :D).
    I will be posting some new images tomorrow of my solution and other modifications i have been working on. I found the perfect part in the AC isle which happened to have a rubber grommet that fits my new shop vac line perfectly!
    #6 Peace11uehman, Nov 25, 2015
  7. Joe Santarsiero
    I saw some guy on YT use a furnace filter at the top. He set a cheap box fan on top of that. Seemed to work fairly well.
  8. Peace11uehman
    Alright so i made some serious progress over the weekend.
    Added:
    - Heavy Duty Wheels with Locks
    -Keyboard / Tool Tray on Heavy Duty Ball Bearing Guides
    - New Compressor
    - Vacuum System
    Whats next:
    - Switch / Button Panel
    - Frame Mounted Monitor
    - Tool Draw
    It is coming along nicely! :D
      File size:
      183.3 KB
      220
      File size:
      183.7 KB
      213
      File size:
      191.5 KB
      215
      File size:
      196.7 KB
      236
      File size:
      211.4 KB
      223
    GrayUK likes this.
  9. Joe Santarsiero
    You're outta control! :D
    Mark Carew and Peace11uehman like this.
  10. Peace11uehman
    Here is the latest work. I am modifying a surge protector to give each outlet it's own switch. The surge protector will be hidden under the keyboard shelf and the switches will be mounted in a gray plastic electrical box. By giving each outlet a switch, it will allow me to control things while keeping the enclosure universal to changes. I will be able to switch things or add things whenever without modifying plugs etc. I will just need to change labels on the switch box.
    I would like to make a nice power box, however i want to keep the unit as compact as possible. I have not found a place to mount a large power box that will give me convenient access to the switches.
  11. Peace11uehman
    Finally got kicked out of the living room, so I decided to make some noise in the garage! Made some serious progress on the vacuum system. Couldn't find the things i needed for my dust shoe, so I decided to do it the hard way! :D
    Here is a sneak peak.
    #11 Peace11uehman, Dec 20, 2015
  12. snokid
    snokid Journeyman
    LOL you have a very understanding wife!!!
  13. Mark Carew
    Cool looking dust shoe! Looking forward to seeing how it works out. I would like to cut one of these for my machine so I hope you will share when done ;)
    Thanks @Peace11uehman
  14. Peace11uehman
    I sure will! I am designing it to be used with the Open Builds router mount.
