My 80w Laser build (1000x1000 cutting area)
Discussion in 'Laser Cutters' started by shadowtec, Dec 29, 2017.
  1. shadowtec
    shadowtec New
    shadowtec published a new build:
  2. Mark Carew
    Following! Really interested to see how well the laser is able to live outside. All the best with the build brother and thank you for sharing with us :thumbsup:
  3. shadowtec
    shadowtec New
    Thanks and I will post more pics when I get the thing done. the only main concern is currently there is 80mm clearance at the elevator door when it is on it's side and the door looks like it is shrinking each time I look at it :)
  4. shadowtec
    shadowtec New
    Not sure if this is the place to add or showoff progress but this was a little while back. the problem is I intend to have a very large cutting area. so I needed to design and make a table lift. I just started using Fusion360 The movie is the render from fusion360 and the picture is the real life result
    I have 4 of these posts which will hold the X/Y Gantry one on each side will have the stepper motor and leadscrew on it the other two will only have the linear rail :)
