MiniMill Z Axis Upgrade with Offset Motor
Discussion in 'CNC Mills/Routers' started by Peter Van Der Walt, Jun 21, 2017.
  1. Peter Van Der Walt
    Peter Van Der Walt published a new build:
  2. GrayUK
    Excellent video. Makes things so much clearer.
    Many Thanks :thumbsup:
    Gray
  3. stephen cia
    stephen cia Well-Known
    Is there a plan for nema 17 similar plate?
  4. Julius
    Julius Well-Known
    mill your own with the mini mill ;)
    RSW and Peter Van Der Walt like this.
  5. Dam
    Dam New
    Hi. Pls ask why its better instead original mounting without belts
    Dam, read the Build Description on the first tab. It is detailed there
  7. Gary Weliver
    So by being able to change the ratio for more torque which may help with a heavier router then does the software adjust the difference or do you have to have all your steppers at the same ratios?
    Set your firmware steps per mm accordingly. The listed BOM is 1:1 ratio though so no change needed, only if you change ratio
  9. wiremonkey
    Hey folks, does anyone have the measurement for this size belt center to center for these size pullies?
  10. Valter Benvegnu
    Hi, will this solution works on a LEAD machine ? I do not have enough clearance to mount the stepper motor on the top of the Z axis.
    I was wondering if this plate allows the upside/down stepper motor to slide behind the back of the Z plate.
    Valter
  11. Peter Van Der Walt
    It looks like it should work! Give it a try and confirm back if you got it working, or shout if you have any issues.
  12. Valter Benvegnu
    Thanks will do.
    Do you know the dimension between the motor and lead screw axis of this plate ? I can make some measurements just to know if in principle it works or a longer plate is needed.
    Valter
  13. Peter Van Der Walt
  14. Valter Benvegnu
    OK, I took some measurement and the mini mill plate won't work. To offset install the Z motor on a LEAD (or workbee) a much longer plate is needed with longer belt and a different mount solution for X drag chain.
    Ideally a replacement custom end plate is needed instead of an additional plate on top of the cbeam end plate.
