Mini V Linear Actuator
Discussion in 'Other Builds' started by Mark Carew, Aug 1, 2013.
  1. Ryan James
    Then just to be a little more critical (it's a character flaw) when you add the motor to the options, it's an additional $24.50, the price of a nema 23...Nema 17 seperately is only $17.50.
    Again, it's a character flaw. Sorry.
  2. Mark Carew
    Aye! whoops Thanks Again @Ryan James working on fixing it now. We could use your help around here :)
    Thanks again bud
    Mark
    Ryan James likes this.
  3. Hadi Ghali
    Dear sir,
    could you please advice me how can I control the speed and direction for V-SLOT Mini V Modular linear Actuator because I need to use it in build electrospinning drum.
    Thanks a lot.
    Hadi
  4. Thurmond Moore
    Mark....I noticed a Delta style machine in the examples BUT it had 6 axis's. What is this style called or is it fictional currently?
    Thurmond
  5. Mark Carew
    That is just an idea I had some time back I have not seen one built yet but I thought it may be cool and may have more accuracy?
    Looking forward to seeing someone give it a go ;)
  6. cronos45
    cronos45 New
    Hi mark, where can i find spacing sizes for the mini V gantry play? Can it have a z block mounted directly the end cap backs?
    #36 cronos45, May 6, 2016
  7. Mark Carew
    Hello
    Yes the hole spacing is 20mm so you can mount right to it.
    Please have a look at the PDF drawings located in the OpenBuilds Parts Resource
    Hope this helps, looking forward to seeing your Build!
    Mark
  8. Logan_La
    Logan_La New
    Hi,
    For Mini-V belt actuator, how close to the end mount brackets do you recommend getting that is relatively safe when shuttling a gantry plate back and forth?
    Thanks,
    Logan
  9. Mark Carew
    Hell Logan, I usually keep about 6mm from the ends unless I am using limit switches
  10. lunknowl
    lunknowl New
    hi, how can i mount the 2040 to this mini v wheel plate (using the 5 hole in center)
  11. Roy de Kleijn
    Hi,
    I like to buy 2 V-SLOT MiniV Modular Actuators and put it together to be able to slide in 2 dimension (X and Y)
    How can I navigate to a specific coordinate? let's say x = 5 cm and y = 10 cm.
    I'm asking for Arduino / Raspberry best practices, used shields to control the stepper motors and maybe also a coding example.
    I'm really looking forward to the answers,
    Roy
  12. Thomas_abc
    Hello,
    I just assembled the V-Slot mini (1m) but I have an issue with the belt. It seems to move too much toward one side of the end mount (see picture) I tried loosening the end plate a bit and moving it "the other way" - then the belt ends un on the other side. I can't seem to reach the sweet spot right in the middle. Any ideas of how I could fix this?
    Many thanks
    Thomas
