Machined Aluminum MagBall Carriages
Discussion in '3D printers' started by UltiBots, Jun 11, 2016.
  1. UltiBots
    UltiBots Veteran
  2. Carlos Joel
    Looks good :)
    Will it (or shouldn't it) have included belt tensioner?
  3. UltiBots
    UltiBots Veteran
    A mechanical belt tensioner system would be a nice mod. This is still being developed. A spring tensioner could easily be added and be all you need.
    Brad - www.UltiBots.com
    Modified C-Beam Bundle
    Dewalt 611
    Elaire 1/8" Collet
    1/8" Single Flute Carbide End Mill
    Workflow = Fusion 360 & Cam > Chilipeppr > Tinyg
    RPM ≈ 25,000 (dial setting 5)
    Feed @ 20"/min (508mm/min), Ramp @ 5"/min (127mm/min), Plunge @ 8"/min (203.2mm/min)
    Pocket cut = 0.25mm rough & 0.2mm finish, 3mm max stepover
    Bore cut = 0.2mm pitch
    Contour cut = 0.25mm rough & 0.2mm finish
  4. Chipsa
    Chipsa New
    Hi,
    nice carriage!
    could you please describe the pulley idler design in more detail? what are the individual components, that would be great. cheers!
  5. UltiBots
    UltiBots Veteran
  • About Us
  • Like us on Facebook
    Donate to FairShare!
