M Cubed CNC Mill
Discussion in 'CNC Mills/Routers' started by M^3, Feb 15, 2015.
  1. M^3
    M^3 Well-Known
  2. sgspenceley
    sgspenceley Master
    Great build, I like how you made box sections.
  3. Outkastaluminum
  4. vonku
    vonku New
    just to show my avatar, aha
  5. MashX
    MashX Well-Known
    Could this machine be used to cut O1 tool steel?
  6. John Williams
    John Williams Well-Known
    No way. Cutting tool steel. 8mm rods and nema 23. Small spindel. Be lucky to cut aluminium. I use a Deckel knee mill and it's a bear, even still, tool steel is a stretch with it. Time and patience. Better with a tormach or vmc.
  7. zaalexander
    Interesting build! Have you found it stable enough resting on the 20x80 alone? I can imagine doing something similar, but doubling up the Y-axis and spacing the extrusions just far apart enough for two carriages to clear. This would increase stability and rigidity in the X-Y plane without increasing the footprint too much. And increasing the power by dual-driving the Y might help with milling too. I'll be looking forward to seeing it mill aluminum!
    #7 zaalexander, Apr 24, 2015
  8. lolocaledo
    Witch software do you use with this CNC to mill aluminium piece ?
  9. Lliam
    Lliam New
    I have a design that's on hold for the moment, but is pretty much the same as your M Cubed. I had even been calling it that also.
    Nice work.
  • About Us
  • Like us on Facebook
    Donate to FairShare!
