Laser engraver
Discussion in 'Laser Cutters' started by Anthony Bolgar, Nov 28, 2016.
  1. Anthony Bolgar
    Surgtek and Derekz like this.
  2. MaryD
    MaryD OpenBuilds Team
    Following. :)
  3. Mark Carew
    So true :thumbsup:
  4. Tracy Ranson
    Tracy Ranson Journeyman
    Since you are not using aluminum plates I would recommend that you use .250 or .375 thick acrylic which should be more than strong enough to hold a laser and the aluminum rails, but if you make the foot print too large you will need something a bit stronger to hold up the gantry.
  5. Anthony Bolgar
    Ya, I decided to use 6mm (1/4") acrylic for now, if I ever add a small spindle, I will upgrade them to aluminum.
  6. Anthony Bolgar
  • About Us
  • Like us on Facebook
    Donate to FairShare!
