laser add-on for C-Beam machine
Discussion in 'Laser Cutters' started by Jurgen, Jun 25, 2016.
  1. Jurgen
    Jurgen Well-Known
    Jurgen published a new build:
    MaryD and David the swarfer like this.
  2. Kyo
    Kyo Master
    That is awesome, I like how you designed it to be swapable with a router. Any pics of items engraved or cut?
  3. Jurgen
    Jurgen Well-Known
    Sorry, but no not yet.
    I am currently searching for some plywood or so to start some cutting / engraving
    I also need a different workpiece carrier - something like a "blade table" or just some Aluminum foil.
    ....but this might be to reflective and the Laser will be all over in the room.
    Enclosing the machine with "LASER shield" seems to be the way!
    I only focused the laser so far and I only managed to burn a spot into my dining table ;-)
    (The Laser was about 15cm away from the surface and switched on for about 2 seconds - focused somewhere)
    JTech has some good cutting and engraving docu you can check.
    It might be a while until I get these results ;-)
  • About Us
  • Like us on Facebook
    Donate to FairShare!
