Large 'Double H-Bot' using 2040 Openbuilds v-slot
Discussion in '3D printers' started by Peter Stoneham, Mar 17, 2019.
  1. Peter Stoneham
    Peter Stoneham published a new build:
  2. Tim Curtis
    It's going to be a huge printer for sure. Which extruder are you going to use? I know you said a pellet extruder, are you going to build your own or purchase one?
  3. Peter Stoneham
    Have been purchasing all the components over the last few days. Being down under in NZ it might take a while to get everything. I am planning on building my own pellet extruder. There aren't many off the shelf available. Have bought a Nema17 with planetary gearbox and a 8mm compression auger to start with. Am thinking of getting a Titan extruder in the meantime.
    Brandon Williams1 likes this.
  4. Peter Stoneham
    Here is a photo and sketch of the auger I am going to use. I am thinking of designing a PEEK tube for it to fit into and use inductive heating to directly heat the auger. The aim is to give me finer regulation over the melt temperature. I have a reel of Litz wire in stock which I will wind over the PEEK tube. I will experiment with varying the spacing to give me an ideal thermal spread over the auger transition and metering zones. All theoretical at present as I haven't even received the auger as yet and it might be austenitic SS...
  5. Peter Stoneham
    I think the best looking 3D printer pellet extruder design I have found so far is one by Mahor Muñiz Cadenas; mahor store
  6. Shortyski13
    Have you priced out all the components yet? I have a design that i put together a year or 2 ago, haven't built yet but finally decided I will, that is similar to yours. Mine is a little smaller so i can get it through a standard sized doorway and decided to not make it that much longer than it is wide. I'm using 2040. I tried to keep it under $1000 but had a reallly hard time doing it, and the only way I can is if I get a lot of it on sale. However, I also didn't want to compromise on a few things, such as a decently thick Aluminum plate to it wouldn't sag, thicker lead screws (I see you are doing belts though), and a quality controller board that will give me more flexibility later (duetwifi) instead of something cheap like an arduino. A heated bed definitely puts it over. I'm curious how you are keeping your costs down on something that big.
  7. Peter Stoneham
    Hi, do you have a real name? Anyway, I have ordered pretty much all of the parts but haven't done a final roundup of costs. Since I am down-under in New Zealand I have to indent everything overseas and my go to source for parts is AliExpress so some parts are still in transit. When I posted there were some custom parts that I hadn't costed. One of them was the laser cutting of 56 x 6061-T6 3mm alloy plates which hold everything together. This is now underway locally and came in at $US220. I will get them anodised $US140 which probably isn't necessary if you were penny pinching. The 30kgs of 2040 extrusion arrived cut to precise lengths from China and the freight on this was a big cost $US170. The z-axis belts (I have gone kevlar) definitely reduced the cost of the build once again due to freighting long ball screws. I am going with a MKS Gen V1.3 controller and Discount Smart Controller LCD which is what I have on my Rigidbot printer and is perfectly adequate for my needs. For my build plate I am going for a honeycomb alloy sheet which is a building cladding product. It's well supported and with mesh bed leveling it will be perfectly fine. Currently not planning to heat the bed which would definitely be a big cost. In fact I am planning to put a thin sheet of plywood on top of my build plate so I can staple the parts skirt to the build plate. Remember that I am planning to extrude at a minimum of 0.8mm in recycled plastic so I am not aiming for extremely high tolerances. I will also be designing models to suit this build size. I just did a quick tally up and even with the anodising I am still a little under the $US1k goal. This does not include an extruder by-the-way... Peter
    2040 Extrusion China Factory 1.JPG Kevlar 2GT Timing Belt.jpg z-axis stepper.JPG Pellet Extruder PEEK Nozzle Concept.jpg Big H-Bot Belts.JPG 3bcde28dc407b11acfa6826db8726d9295e2f7f1.jpg
    #7 Peter Stoneham, Apr 16, 2019
  8. Hannah
    Hannah New
    Have you started building this yet?
    I am trying to spec out a 1000mm cubed printer myself
    How is the stability of this large construction, I thing I should use C-beam
    FabRum likes this.
  9. Peter Stoneham
    Hi Hannah,
    it is built and working. The stability is extremely good which is primarily attributed to the unique Double H Belt design. At the design stage I considered many extrusion options and now that it is built I wouldn't go back and change any of the extrusions if I made it again.
    Mark Carew, sharmstr and GrayUK like this.
  10. Hannah
    Hannah New
    Ok, thx.
    That gives me confidence in my build
  11. Mark Carew
    Amazingly cool build @Peter Stoneham this is a work of art! Well done and thank you for sharing with the community :thumbsup:
  12. Peter Stoneham
    @Mark Carew - thanks for your feedback and thanks to OpenBuilds as it would not have been created without your collective vision!
  13. Peter Van Der Walt
    Glad to see you found a new home, personally followed your work closely on G+ back in the day!
  14. Peter Stoneham
    Hi Peter, sorry for the very late response... I see you are a long standing member of the OpenBuilds team based in South Africa. I have such a bad memory - did you own a Rigidbot 'back in the day'? I still have mine and have followed the Rigidbot/Reliabuild crowd over to MeWe. Currently building a zoetrope called Whirling Dervishes to take to a music festival in Feb
    zoetrope - first light.jpg .
  15. Peter Stoneham
    Such a late response but Thanks Mark for your very encouraging response - much appreciated!
    Chaingun427 and Mark Carew like this.
  16. Brandon Williams1
    Do you have plans/parts list posted? This is my first time on this site and I don’t know where to look. Thanks and wonderful work!
  17. tjmitchem
    tjmitchem New
    I'd be interested as well.
    EugenePo likes this.
  18. Bartman76
    Bartman76 New
    Hi Peter,
    I am also very interested in your large printer design. Also new to the site and not sure where to look.
    I agree with Hannah and would like to use the Duet Wifi.
    Hope you can help a fellow Down Under Builder and G'day from Oz.
