High Intensity Dive Light
Discussion in 'Other Builds' started by Robert Huxford, Mar 22, 2017.
  1. Robert Huxford
    Robert Huxford published a new build:
    What are your plans for charging? Some form of induction or will the case need to be opened for battery removal?
  3. snokid
    snokid Journeyman
  4. Robert Huxford
    The previous one I built had a lead acid battery with a removable 'screw in' back sealed with a neoprene "O" ring. Battery will be removed for charging. Will be charged with a Model airplane/model car charging system. Battery pack will swapped between dives. (36 volt, .5 to .6 amps, enough batteries for approximately 2 hr duration). Have not looked at a waterproof plug for the battery but am interested.
