eccentrics
Discussion in 'General Talk' started by SJD, Nov 3, 2014.
  1. SJD
    SJD New
    Started on a ox build but just haven't got enough done to post a build.
    I know eccentrics are only $3 but I couldn't pass up making these.
    Hex is for 1/2" wrench .187 deep with .060 washer to equal .250 space(probably need to mill a wrench to .18 thickness to adjust them)Hole is offset to print in openbuilds store.
    GrayUK likes this.
  2. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Excellent work SJD. :thumbsup:
    Tweakie.
  3. SJD
    SJD New
    Thanks Tweakie! I have a conversational program called simple cnc i bought awile ago and love it..ill be ordering parts soon to get going on my build
  4. David the swarfer
    hey SJD, I also made my own eccentrics, using 10mm square steel bar. set it up in the lathes 4 jaw chuck to turn the spigot, then made a 0.8mm spacer to offset the holes and did that as a second op.
    now need to make a lot more (-:
  5. SJD
    SJD New
    Nice David..I think we seen a challenge and couldnt let it pass by..i went with aluminum because my hobby mill works with ease..steel would be better choice but works it too hard.
  6. David the swarfer
    not a challenge :) , necessity since I am in Africa and importing from the openbuilds store is stupid expensive.
    I'll be making V wheels too.
