E OX
Discussion in 'CNC Mills/Routers' started by Priit Paat, Dec 22, 2015.
  1. Priit Paat
    Priit Paat Well-Known
  2. Steven Bloom
    Steven Bloom Veteran
    So what is your frame going to look like ?? Do you have a model to view ??
    Thanks Steven
  3. Priit Paat
    I have not yet even decided exactly, still looking around.
    Before I also have to be able to work with my electronics.
  4. Priit Paat
    There are even Mach3 XML file on that bob CD, but still no luck. Slave not work, when running on G-Code.
  5. snokid
    snokid Master
    I don't know the answer as I have never used mach, but is there different software that you could try?
    I bet there's a check box somewhere you are missing....
    good luck I will be watching for the answer....
  6. snokid
    snokid Master
  7. Priit Paat
    Thaks for replay snokid!
    I have come to the same conclusion. Do breakout-board does not support USB or have a problem with RNR motion plugin which must be led between the computer and the card.
    It seems that it is a pirated copy.
  8. amos ben amos
    the easiest way to solve the problem will be to connect the 2 x drivers to the same axis port on the controller
  9. amos ben amos
    make shore you are connecting them in a way they will rotate in different direction
  10. Priit Paat
    Thaks for replay amos ben amos!
    That would be one option, but is also the most appropriate solution? It is still debated in forums for that solutions is good or not?
  11. amos ben amos
    i used to be connected that way for a while and had no problem, i also read in planet cnc forum that it's perfectly fine
  12. amos ben amos
    it can be a problem if the drivers is build in the controller because most of time there is not enough amps in one driver to drive 2 motors but as i can see its this is not the way you are connected
  13. Priit Paat
  14. Steven Bloom
    It just depends on how much power you need to move the axis. Most 3d printers use 2 z motors on one controller. Even my very heavy sea-ox was able to move on 1 y axis motor
  15. Priit Paat
    Plan to use on Y axis two those stepper motors: 3PCS 1.9Nm Nema 23 Stepper Motor 2.8A 4-wires 6.35mm Shaft DIY CNC Router Mill
    Right now i have set 1/8 microstep and 2.8A current of each motor driver. Are that correct?
    The plan to begin mill mostly hardwood/softwood.
    Maybe i use ooznest frame kit and raise z axis a little deeper cut - swapping lower rails 40 to 80.
    Generally, it would be more to the liking Cbeam solution.
  16. Steven Bloom
    Looks good on the 2.8amp setting. The microstepping is a choice thing. I actually run mine at 1/2 microstep. It gives me 2/100th of mm accuracy. That's enough for me and I can always change it if necessary
  17. Priit Paat
    Added two drivers to board Y port and swapped one pair motor wire for reverse run - looks like working that way. Thanks guys for that!
    I do not know if there are not any complications later. We hope, however, that not.
    Steven Bloom likes this.
  • About Us
  • Like us on Facebook
    Donate to FairShare!
