Dragon Portable CNC Plasma Cutter
Discussion in 'Laser Cutters' started by Metalguru, Jun 29, 2016.
  1. Metalguru
    Metalguru Master
    Metalguru published a new build:
    Paul Stoller likes this.
  2. corpore
    corpore Well-Known
    I'd like to know, whether this concept was actually realized, or if it is still work in progress.
    cheers, Fred
  3. Metalguru
    Metalguru Master
    As the originator of the design, I have not built this. This is clearly labelled as a concept.
    You Could see the Dragon Too build concept, which is another concept machine that is actually being built.
    MG
  4. corpore
    corpore Well-Known
    ... I know, it is labelled as a concept (one that should be, after some improvements, taken up). I merely wanted to know whether you've actually acted on it, as I could not necessarily assume that your entries here are up to date. ... no reason to get stroppy guru. I am familar with dragon too, ...a concept that doesn't interest me as much, because it doesn't scale.
    Fred
