Distance per rotation - belt system
Discussion in 'General Talk' started by Charles Fried, Aug 1, 2017.
  1. Charles Fried
    Hi All,
    Can someone clarify the formula to calculate the distance travelled for one full motor rotation on my belt driven system?
    I have the V-Slot® Linear Actuator Bundle however I changed the pulleys for the 20 tooth.
    Thanks in advance,
    Charles
  3. Charles Fried
    Hi Peter,
    I'm aware of this site but I would like to know the calculation without taking into account the stepper.
    Surely it's pretty straight forward?
    Thanks,
    Charles
    Pitch x number of teeth...
  5. Charles Fried
    Thanks for the prompt responses, however the RepRap Calculator and formula above give me different results:
    Pitch: 3mm
    Number of teeth: 20
    3 * 20 = 60mm
    Now according to RepRap, if I full-step (200 for full rotation) with my current setup I get 3.333 steps/mm.
    3.333 * 200 = 666.6 / 10 = 66.6mm
    Where am I going wrong?
    #5 Charles Fried, Aug 1, 2017
    Steps per mm IS NOT mm per Rotation. So wont be the same.
    Rotation = 60mm. Each mm needs 3.33 steps (per calc). So to move 60mm you need 60x3.33 steps = 199.8 steps. Close enough to 200 steps so all matches. 3mm doesnt divide as nicely as say 2mm GT2 so rounding error on the Prusa Calc explains the missing 0.2 step.
    :) See just use the Calculator and call it a day
    #6 Peter Van Der Walt, Aug 1, 2017
    GrayUK likes this.
  7. Charles Fried
    Thanks for clarification, I'm not using a stepper hence this post.
  8. Joe Santarsiero
    Joe Santarsiero OB addict
    You can also look up the pulleys belt pitch diameter and take the circumference.
