D-Bot CoreXY printer
Discussion in '3D printers' started by Bon Thomassen, Aug 28, 2016.
  1. Bon Thomassen
    Bon Thomassen Well-Known
    Bon Thomassen published a new build:
  2. Max Tepermeister
    Max Tepermeister Well-Known
    Bon, That sounds exactly like what I am doing! I have had an I2 for a while and decided I wanted to design my own and I was also inspired by Carl's bot!
    I know that this is pretty early in your design process, but because I'm designing a very similar printer, I'll tell you some things that I learned while designing/partially constructing mine
    You currently have the carriage so the horizontal bar end butts up against the face of the carriage. I originally had the same thing, but I found that it had 2 issues.
    1: It requires the cut on that horiz. bar to be perfect because if it is too short you won't get a very solid connection, and if it's two long, then it won't fit.
    2: There isn't a commercially available (that I could find) way to strongly attach the bar to the carriage. That means that the attachment will have to be printed. It was hard for me to design a printed part that was rigid enough to go there.​
    What I would consider instead is putting the bar so one of the faces mounts against the carriage. That does require drilling two holes in the bar into which you can put a bolt that screws into the carriage. If you're willing to drill out the threaded portions in carriage, you could screw the bolts into nuts in the bar instead. There's probably other things you can do as well, those are just the two that occurred to me. As a side benefit, I found that this also allowed me to mount my belt guides with the same bolts.
    Another thing is that the Z axis has been really hard to do well. I've pretty much got the X/Y done on my machine, but the Z is giving me lots of trouble. (It's really hard to drill everything perfectly and that leads to some things being a bit out of alignment). Designing for oversize holes and some kind of fitting jig is your friend here.
    Good luck with your design and build! (and if you have any suggestions/ideas for my printer, let me know as well!)
    ~Max Tepermeister
  3. Bon Thomassen
    Thx Max,
    I will consider your advise. However, I'm a Teacher and at my school, we have a very accurate metal-saw. Also I'm thinking of cutting the extrusion slightly to large and grinding the excess away. I've uploaded a new drawing with the start of the z-carriage, so you can imagine how it's going to function. I will use two z-axis steppers and T8x8 lead-screws positioned at the middle of the heated bed.
    If you have any more advise I'll appreciate it very much.
    Regards Bon
  4. David Bunch
    David Bunch Veteran
  5. Carl Feniak
    Carl Feniak Master
    @Bon Thomassen glad my make inspired you and I am curious what changes and improvements you will make. There are already a D, E, J, & S (Spiff) remixes so there are lots of great ideas to inspire you. Since it is open source and easily hackable/modifieable it is to make it your own version and please do.
    The major change from the original C-Bot to D-bot was the offsetting of the Z axis by David Spaulding (hence D-bot) and is a Z axis option in the C-bot Remix/V2.
    Check out this photo gallery for inspiration:
    Photos from posts
    Bon Thomassen likes this.
  6. Bon Thomassen
    Yes, it's bases upon Carl Feniaks C-Bot design but I'm using the D-Bot implementation of http://www.thingiverse.com/thing:1001065 for the Z-Axis . I want a build space of 300x300x300 mm so I'm using the 500mm openbuilds V-Slot 20x20 and 20x40 extrusion. I ordered the majority of the parts but I don't have a BOM yet. The total costs of the build will be around 800 Euro.
  7. Bon Thomassen
    Hi All,
    I'm Trying to upload the FreeCAD files I made but it's not possible for me to upload any file. When I try I receive the message that I tried to upload an unsupported file type. Any suggestions?
  8. David Bunch
    David Bunch Veteran
    How about putting them into a zip file & uploading that?
    Carl Feniak likes this.
  • About Us
  • Like us on Facebook
    Donate to FairShare!
