C-Beam Lead Screw CNC Mountain
Discussion in 'CNC Mills/Routers' started by Savvas, Sep 11, 2016.
  1. Savvas
    Savvas Journeyman
    Savvas published a new build:
    GrayUK likes this.
  2. Anthony Bolgar
    Very creative way of doing things, by using wooden parts to get a functional machine that can then make more permanent parts out of stronger materials. Kudos!
  3. Savvas
    Savvas Journeyman
    Thanks! The proof will be in the pudding - so to speak, but I am feeling optimistic about this build.
  4. Bad Sequel
    Bad Sequel Veteran
    Keep up the good work Savvas! Looking forward to the next video. :thumbsup:
  5. GrayUK
    GrayUK Master
    Excellent set of videos! Very well explained by yourself. :thumbsup::thumbsup:
    I shall look forward to up and coming videos.
    Good Job. Well done so far. :)
    Gray
  6. Savvas
    Savvas Journeyman
    Thanks Gray :) I just wish I had more time to work on this!!
  7. Savvas
    Savvas Journeyman
    Thanks! The next video is probably going to be a little longer than the other, as I'll be fitting and wiring the steppers, a sub waste-board and wiring and programming the VFD.
    MaryD, Bad Sequel, GrayUK and 2 others like this.
  8. lunknowl
    lunknowl Well-Known
    hi can you scale the gantry to it fit for 20x40 frame? thanks
  9. Savvas
    Savvas Journeyman
    Hi, I guess I could but where would the lead screw go?
  10. Bad Sequel
    Bad Sequel Veteran
  11. Davey Rance
    Davey Rance Journeyman
    Great build. You would not happen to have a link to the adapters that you used for the water tubes per chance would you. I have the same spindle and the little barbs just feel way to flimsy.
  12. Savvas
    Savvas Journeyman
    Hi Davey, have a google for LAPN8X1 Nipple G1/4 - M8x1 for SKF System 24 Lubricators.
  13. Davey Rance
    Thanks for that Savvas that looks fantastic. They are not that common in the USA but it think i can get a couple.
  14. silopolis
    silopolis Well-Known
    Hi Savvas
    So great to have you join the OpenBuilds crowd ! Already learned so much following your chanel and this is another excellent series
    Will surely become a reference build . . .
    Hardly waiting for the next parts
  15. Savvas
    Savvas Journeyman
    Thanks, I'm already thinking about how to design the next set of plates. I just wish I had more time for this!!
    silopolis likes this.
  • About Us
  • Like us on Facebook
    Donate to FairShare!
