Based on 608 tube Plasma Cutter
Discussion in 'Laser Cutters' started by carlos515, Feb 17, 2020.
  1. carlos515
    carlos515 New
    Lovely remix of my old design (openhardwarecoza was my profile before I joined OB hehe!)
    Love the water table!
    Keep us posted - would love more pics and videos when it is in action.
    Sadly years ago I had to abandon that build when the guy I was building it with got into some family strife and it never got finished, so this is bitter sweet :)
    Giarc likes this.
  3. carlos515
    carlos515 New
    Thanks Peter ,
    Your original design is very good. In building the table I keep coming across different ideas to implement in the table. More pics and material lists will be added in the future.
  4. LoCo DIYer
    Looking great! Can't wait to see how this turns out for you. If you end up being happy with it, i would like to build one myself. Best of luck on your build and keep adding updates!! Would love to see more pictures as you progress.
    Cheers!
  5. LoCo DIYer
    I do have just one question, what is the working/cutting size of your table?
    With that design it should scale well to any sane size - just adapt the steel lengths accordingly, add extra bracing as needed
    LoCo DIYer likes this.
  7. carlos515
    carlos515 New
    Well I finaly got around to setting up the table. I have the basics set up to move all the axis .I will work on the Proma THC next. The brains of the table is a PoKeys57E . Running on Mach3.
  8. carlos515
    carlos515 New
    The cutting , working size of the table is 4' x4' .
  9. carlos515
    carlos515 New
    Well after a break , I am back at the table. I have decided to use gear rails for my x and y axis .
  10. carlos515
    carlos515 New
    I am working on a floating z axis with ohmic touch off.
  11. carlos515
    carlos515 New
    I have switched from Mach 4 to LinuxCNC. I have recieved my Messa 7i76e and my THCAD boards. I was having problems with the hardware in Mach 4. I will set up the new system shortly and take it for a test drive.
    I also have a robot3t ohmic sensor arriving , hopefully , soon.
