Aluminum Ox
Discussion in 'CNC Mills/Routers' started by richthorn, Mar 15, 2014.
  1. richthorn
    richthorn New
    richthorn published a new build:
  2. Mark Carew
    Well done Richthorn! Looks like you have the speeds dial in on this OX.
    What are you using for the controller? EDIT: I see your using the Gecko G540 nice!
    Keep up the good work
    p.s. gave you 5 star rating but spelled your name Richard sorry about that ;)
  3. richthorn
    richthorn New
    Well it is my name so we won't fault you :thumbsup:
    I'm using a Gecko G540 and some 380oz/in motors. The company I ordered from had some more powerful motors but they were 3/8" shaft and wouldn't work with the pulleys so I went with these guys but I'm not complaining. Should be a seriously capable machine once I slow it down a bit on the feedrate for cutting.
  4. Mark Carew
    they are more then enough for sure!:thumbsup: Sounds like a great setup for this machine, looking forward to your first cuts. :)
  5. richthorn
    richthorn New
    Just tested the X-Axis at 1000IPM and it didn't miss a single step. Quite the machine you designed :thumbsup:
  6. Mark Carew
    Thanks @richthorn :thumbsup: Glad your liking it and I hope it brings you as much fun as it does for me!
  7. brjig
    brjig New
    What mounting plates are you using for the z-axis motor?
  8. SlowBipe
    SlowBipe New
    Can you tell me with specific steppers you used with this build and where you bought them? Also wondering where you picked up your 18 tooth pulley's for the drives?
