10 x 5 ft plazma table build
Discussion in 'Laser Cutters' started by Dave420, Sep 10, 2016.
  1. Dave420
    Dave420 Well-Known
    Dave420 published a new build:
  2. bnbellis3377
    bnbellis3377 Well-Known
    Hi Dave
    I like your build, was thinking about doing something along the same lines. Did you miter the ends of the valor so that they would slide under each other or just but them up. I have looking at different options on what I want to build. I built a cbeam and have been playing with still trying to get it all dialed in then I could make my own plates and maybe figure out a way to miter the ends of the vslot Keep updating thanks
    Brian
    Dave420 likes this.
  3. Dave420
    Dave420 Well-Known
    Hi bnbellis The Vslot are but connected with a double tee nut on the out side and 10ft backing plait on the inside of the square tube frame which allows adjustment. Double Tee Nut™
  4. Dave420
    Dave420 Well-Known
    Hi bnbellis: Yes the Vslot are but connected with a double tee nut at the connection. A one peace 10ft backing strip/plate was made too fit on the inside of the square tube steel. I hope that helps explain what i did better. Thank you. Double Tee Nut™
  • About Us
  • Like us on Facebook
    Donate to FairShare!
