Solidworks 2014 Parts Library 1.6
Complete set of OpenBuilds parts
  1. Rob Stehlik
    OpenBuilds Parts for your projects!
    Solidworks 2014 OpenBuilds Parts Library
    Official OpenBuilds Part Models commissioned by OpenBuilds,LLC
    The goal when creating this library was to produce simple and accurate models. Samples of all parts were measured directly. PDF drawings of the machined parts are provided for reference.
    To use this library effectively, you should add it to your Design Library in Solidworks:
    Watch what happens when you drag and drop screws over the holes in a plate! They will snap into place automatically. When you release the mouse button, you can choose the screw length.
    Disclaimer
    By downloading any information or materials from this website you agree and acknowledge that all information or materials are provided as is without any guarantees or warranty of any kind. In association with any downloads or any other information or materials contained on this website, OpenBuilds, LLC makes no warranties of any kind, either express or implied, including but not limited to warranties of merchantability, fitness for a particular purpose, of title, or of noninfringement of third party rights. Use of the download by a user is at the user's risk. OpenBuilds, LLC is not responsible for accuracy or reliability of any content or safety recommendations or lack thereof. Use of any information from this website is at the user's own risk. This website is community driven and by joining you are agreeing to all terms and conditions set forth, therefore you agree that as a user of this site you are solely responsible of all of your own actions.
    Ownership
    The 3D models and/or materials made available by OpenBuilds,LLC are protected by copyright and other intellectual property rights which includes all images and digital 3D model information. OpenBuilds,LLC owns all rights, titles and interest and reserves all rights in and to these materials not expressly granted to you in these Terms.
    NO REPRESENTATIONS OR WARRANTIES, EITHER EXPRESS OR IMPLIED, OF MERCHANTABILITY, FITNESS FOR A SPECIFIC PURPOSE, THE DOWNLOAD MAY BE USED WITHOUT INFRINGING THE INTELLECTUAL PROPERTY RIGHTS OF OTHERS, OR OF ANY OTHER NATURE ARE MADE WITH RESPECT TO INFORMATION OR THE DOWNLOAD TO WHICH INFORMATION MENTIONS. IN NO CASE SHALL THE INFORMATION BE CONSIDERED A PART OF OUR TERMS AND CONDITIONS OF SALE.
Recent Reviews
  1. Jet Jaguar
    Jet Jaguar
    4/5,
    Version: 1.6
    The V-Slot Gantry Plate 20-80mm.PDF file is not accurate according to my measurements.
  2. mert94
    mert94
    Version: 1.6
    Nice! This will save me and a lot of others a lot of time! You're awesome!
  3. thunderbolt
    thunderbolt
    Version: 1.6
    Downloaded the Library to use in Fusion 360. Will be a great help in planning a CNC router build. Thanks Rob.
  4. vvr0ngpath
    vvr0ngpath
    4/5,
    Version: 1.4
    Missing Reduction Plate Etc
    1. Rob Stehlik
      Author's Response
      There was some hesitancy to include the reduction plate in the Parts Library since they didn't perform nearly as well as expected.
  5. Dan elder ristori
    Dan elder ristori
    Version: 1.4
    Excellent. Well done!!
  6. maestrofarraz
    maestrofarraz
    Version: 1.3
    Excellent. Thanks for your great job!
  7. Alan Gibson
    Alan Gibson
    Version: 1.3
    Awesome work.
    I've found one problem though. When trying to import Linear Actuator End Mount into OnShape, the import fails with "The following 1 parts failed validation and could not be imported: 1 unnamed". I'd much appreciate if you could fix this, as I don't have a copy of SolidWorks.
    1. Rob Stehlik
      Author's Response
      Sorry for the late reply. I have no experience with OnShape, so I probably won't be much help. Does this occur with other parts as well? Can you import STEP or IGES files into OnShape?
  8. Arloag
    Arloag
    Version: 1.2
    Hi Rob. Great job!! You help a lot of people to save many many hours with our designs. Thank you very much!!! ;)
  9. Bullseye Body
    Bullseye Body
    4/5,
    Version: 1.2
    I successfully loaded the file into Solidworks 2016, however each time I select a component to add to the drawing, I continue to receive multiple errors stating "Could not load Solidworks DLL: " and gives multiple file names all ending in .dll after that warning message. Could you please let me know if that's an error on my part? The entire library loads correctly into Solidworks and appears in the design library at the right pane, but once a component is clicked and appears in the drawing pane, that's when the errors began to occur and the only way to stop them no matter what you click, is to "X" out of the drawing.
  10. Jason Kraft
    Jason Kraft
    4/5,
    Version: 1.1
    This is almost perfect, but I'm having trouble seeing the M5 low profile 10mm screw. It's appearing invisible for some reason. Not sure if this is something stupid I'm doing in Solidworks or if it's an issue with the part itself.
    1. Rob Stehlik
      Author's Response
      I'm not sure what would be causing this. I was just recently using these screws in an assembly and they showed up fine. I have seen situations where you accidentally change a parts display properties in the feature manager, and it can be very disconcerting.
