      Hy guys !
      I want to build a multimaterial 3D printer that could print plaster, clay, concrete, …etc. The printing head will be changed depending on material I want to use.
      It's a cartesian style 3D printer. Nothing special, except its size (150x150x150 cm), and the motors : indeed, I need powerful motors because the heads may be heavy (specially when I will use concrete).
      I already built a 3D printer 50x50x50 cm based on the Maximus. It works well now (thanks to several OpenBuilders who helped me to make it successfully !)
      WHY ?
      I want to produce sculptures using 3D printing (I'am architect and artist as well).
      ELECTRONICS
      - ARDUINO Mega 2560 + RAMPS 1.4 + power supply 12V
      - Leadshine DM 5042 external driver + Power supply 36V + NEMA 23 stepper motor
      SOFTWARE
      - Repetier Host to communicate with the Ramps
      - ARDUINO to upload the firmware (Marlin)
      MECANIC
      - V-Slots rails 40x40 + home-made plates
      - everything goes fine on the side of the build
        TROUBLE
        I have a little trouble with the electronics and the Leadshine drivers ; the motor NEMA 23 reacts when the ARDUINO board receives a command … but not as expected : indeed, it makes a little noise like a "zzzzzzzzzzzzzzzzzzz" instead of moving normally.
        I checked several times the connections and all the system. It seems to be fine.
        I do not understand where the trouble comes from. Anyone could help me ?
    I'm a artist and sculptor : I want to create sculptures using 3D printing (multimaterial such as plaster, clay, concrete …)
