      4 votes
      Specifications:
      Output wavelength: 450 nm
      Output Power: 2.8W blue laser
      My first tests:
      Laser intensity: S25 (0 - 255)
      Feedrate: F350
      After the laser processing, it looks burned. But after cleanig it looks great!
      image09.png image11.png image10.png image12.png image13.png image16.png image15.png image14.png
      Two easy ways to create a G - Code:
      1.) Create a G - Code with a cam Software (I use Estlcam):
      - Take a DXF - File and generate line by line with 0,3 mm distance.
      - Processing time for the Ornament 20 min.
      - Send the G - Code to the machine (I use Repetier Host Software).
      2.) Create a G - Code from image with the Inkscape extension "Raster 2 GCode generator":
      - Processing time for the Logo (100x100 mm) 2 hours.
      - Simple change of laser power with Windows Editor.
      - Windows Editor change all Laser power "S255" to "S25".
      - You can change the MCode and the laser power for your machine.
      At last a special thanks to oni305 | OpenBuilds for the great Inkscape extension "Raster 2 Laser GCode generator".
      Laser Engraver Control Board + Inkscape extension | OpenBuilds
      It's great to engrave a jeans!
      :) Attention: It is your own risk, when you set your jeans on fire! :D
