      The Davomatic is a Cantilever design printer. I choose this style because I had saw a lot of cantilever printers on Open builds and other tinkerer site but only a few that had been successfully built and saw that as a challenge. This build was built with off the shelf openbuilds parts and other various parts found on THingiverse.com. I did find out why this printer had such an unpopular following. it has been a challenge building this, but the actual design and build wasn't that hard, but it was a bit challenging to get it to print nearly perfect parts due to the amount of vibration generated during the printing process. I am successfully printing functional parts. More on that later in the build process. I am labeling this as a work in progress because I want to completely eliminate the vibration which is the final step in getting this printer to any resemblance of a professional grade printer.
      Printing area : 50cm x 50cm x 65cm
      Bed Autoleveling with capacitive sensor (coming in 1 week)
      PSU : 12V 30A
      Controller : Ramps 1.4 and Arduino
      Hotend : E3D V6
      Extruder : Wade Extruder
      Material : PLA, ABS, PETG, Nylon, NinjaFlex, TPU
      Heated bed : 32cm x 32cm , 120V, 200W
      Steppers : 4 nema17
      The Z Axis is currently only running with 1 nema17 motor mounted at the bottom of the axis and hasn't had any issues of overheating or missed steps. (working progress)
      Parts list:
      Printer -
      1 - Ramps 1.4
      1 - Arduino Mega 2560
      1 - E3D v6 hotend
      1 - KEENOVO Silicone Heater 310x310mm
      1 - uxcell SSR-40 DA 40A DC 3.2-32V to AC 24-380V SSR Solid State Relay
      1 - CCTREE Clear Glass Heat Bed 310x310x3mm for 3D Printers
      1 - [Gulfcoast Robotics] Anodized Aluminum Heated Bed Build Plate 330x330mm
      1 - 12v 30a Dc Universal Regulated Switching Power Supply 360w
      1 - Power Socket 6A Fuse Switch Male 10A 250V 3 Pin PSU Switch
      Wade's Extruder BOM -
      1 - Nema17 Motor
      1 - extruder body printed part, PETG 60% infill
      4 - M3 10mm screw
      1 - small gear printed part, PETG 60% infill
      1 - M3 6mm set screw
      1 - large gear printed part, PETG 60% infill
      1 - printed spacer, PETG
      1 - 8mm hobbed bolt
      1 - 8mm lock collar
      1 - M4 4mm set screw
      2 - 688 ball bearing 8x16x5
      1 - idler printed part, PETG 60% infill
      1 - 625 2RS ball bearing 5x16x5mm
      1 - M5 20mm screw
      3 - M3 20mm screw
      1 - M3 nylock nut
      2 - M3 50mm screw
      4 - M3 nut
      4 - Precision Shim 10x5x1mm
      2 - Spring 1.2mm 7.5x5x20mm
      1 - E3D V6 hotend
      2 - 20x20 extrusion black 80mm
      4 - M5 10mm screw
      2 - M5 T Nut
      X Axis -
      60cm - V-Slot® 20x60 Linear Rail (X Axis)
      1 - Nema17 Motor
      1 - GT2 Timing Belt Pulley 16 Teeth Bore 5mm Width 6mm
      1 - Build Plate
      4 - Delrin V Wheel Kit
      4 - Eccentric Spacer (6mm)
      4 - Aluminum Spacers (6mm)
      4 - Low Profile Screws M5 (25mm)
      4 - M5 ThreadLock nuts
      4 - 40mm aluminum square stock
      8 - M3 Cap Head Screws (20mm)
      8 - M3 ThreadLock nuts
      4 - M3 flange bolts
      4 - heated bed springs (20mm)
      4 - M3 Thumb Nuts
      120cm - 2GT-6 PU Timing Belt Width 6mm
      4 - wire ties
      1 - Smooth Idler Pulley Kit
      Y Axis -
      70cm - V-Slot® 20x80 Linear Rail (Y Axis)
      1 - Nema17 Motor
      1 - Motor Mount Plate - NEMA 17 Stepper Motor
      2 - Tee Nuts - M4
      2 - Set Screw - M4
      2 - V-Slot® Gantry Plate - Universal
      80cm - 2GT-6 PU Timing Belt Width 6mm
      8 - M3 Cap Head Screws (8mm)
      2 - Eccentric Spacer (6mm)
      2 - Aluminum Spacers (6mm)
      1 - Wade Extruder (listed above)
      Z Axis -
      100cm - V-Slot® 20x80 Linear Rail (Z Axis)
      104cm - 8mm Metric Acme Lead Screw
      1 - Nema17 Motor
      1 - 5mm * 8mm Flexible Coupling
      3 - M3 Cap Head Screws (55mm)
      1 - Anti-Backlash Nut Block for 8mm Metric
      2 - Flanged Bearing 688ZZ 8x16x5
      2 - Lock Collar
      1 - V-Slot® Gantry Plate - Universal
      2 - Threaded Rod Plate - NEMA 17 Stepper
      6 - Self Tapping Screw
      3 - Aluminum Spacers (35mm)
      1 - Micro Limit Switch
      Extruder & Hotend -
      25cm - V-Slot® 20x60 Linear Rail (Extruder and hotend supports)
      2 - Low Profile Screws M5
      2 - Tee Nuts - M5
        This Build is actually Completed, but I am still working on tweaking the vibration I am having in the final prints. I have gotten them to an acceptable print quality but want to perfect it further. will re-post my final firmware. By the way, I am using Marlin 1.1.8 for this build!
    Indie i2's success let me know that it could be built, and I wanted to increase the build volume.
