      6 votes
      C-Beam Prefab Untitled
      The C-Beam Prefab Untitled build is designed to accommodate a 610mm x 910mm x 50mm cutting envelope and uses a minimum number of custom parts for the initial build. The end goal is to build a robust machine with a large cutting envelope that can cut a range of materials including aluminum.
      cbeamprefab-l.gif more info coming soon...
        Thanks for all the great reference material, this project would not be possible without Kyo's C-beam Sphinx,
        Moag's C-Beam Machine XLarge, Mark Carew's OpenBuilds OX CNC Machine and smw3d's R7.
    This build is designed to accommodate a 610mm x 910mm x 50mm cutting envelope and uses a minimum number of custom parts for the initial build. The end goal build a robust machine with a large cutting envelope that can cut aluminum plates.
