      I decided to double the size of the standard c-beam package and this is that project.
      Size enlarged to 1000mmx1000mm. Extending the sides and back to the 1000mm extruded aluminum.
      Bear in mind, you will need a solid worktop of at least 42"x42" for this build. You need to make a space for this first or you may run into space constraints issues.
      I built my base out of treated 2x4 lumber, 3/4" mdf flooring as a top base with 1/2" mdf over that.
      The only issue I ran into was that I enlarged the work surface as well. I decided to go back to the 12"x12" and as suggested I will add taller spaces on the gantry plate so I can go beyond the Y axis stepper to fully utilize the project base.
      I will update and add pics and videos later if possible.
      My first cuts[​IMG]
      As you can see I tested the wrench file on this scrap mdf, also wanted to do a test run of the Open Builds Logo.
      Paul Stoller, snokid and GrayUK like this.
    I wanted to get into the world of hobby cnc and make items for sale or friends, etcetera.
    I admired the site for C-Beam Open Builds and Tracy Ranson was a great help and an inspiration for the build.
