Much4 - A printed version of the Laser V
Discussion in 'Laser Cutters' started by skarab, Jul 1, 2014.
  1. skarab
    skarab Journeyman
    skarab published a new build:
    Tinbasher likes this.
  2. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Excellent work Skarab - a build to be proud of :thumbsup:
    Tweakie.
  3. Mark Carew
    Well done! love the way this turned out and how precise the cuts come out. I have to build one thank you for sharing.
  4. winand
    winand Well-Known
    Looks really clean, good job!
    Wondering what power the laser diode has?
    Engraving aluminium and glass is possible is see (or plexiglass?)
  5. skarab
    skarab Journeyman
    Thank you for your comments :)
    @winand no glass or aluminum, just engraving wood, pvc, plexiglass and cutting paper, stickers and tinkers materials.
    The diode is a "2W 445nm Blue laser module" from ebay. I just ordered a 3W diode to test.
    After a few hours of use, I recommend for more than 1W diode, active cooling of the laser module to avoid distorting the x-carriage.
  6. Tweakie
    Moderator
    Just a note regarding personal safety here...
    Unless adequate precautions are taken (and they are quit extensive) laser engraving / cutting PVC, or any products containing PVC, can be extremely dangerous to our health (it does not do the machine any good either).
    Basically the laser beam will vaporise the PVC liberating Chlorine gas which will combine with the natural moisture in the air to produce a form of Hydrochloric Acid.
    The use of an adequate fume extraction system is always recommended when using lasers but please remember that unless specialist in-line filters are used you could be poisoning Bambi outdoors.
    Tweakie.
  7. skarab
    skarab Journeyman
  8. Tweakie
    Moderator
    Quite honestly, I do not know the answer to that question - I just avoid lasering anything containing PVC.
    (I currently use an 'activated charcoal filter' in my extractor which removes the smell of acrylic cutting very well - I did have a HEPA filter in-line as well but they are expensive to maintain (replace) so I am back to just using the charcoal now).
    Tweakie.
  9. winand
    winand Well-Known
    Thanks for the info and the health tips :thumbsup:
  10. Dat Chu
    Dat Chu New
    Can I have some recommendations for what filter to get? Also, are the fume extractors simply tubes available from Home Depot?
    I notice that you have a bunch of 3d printed parts. Is the belt clamp in the skp file?
  11. skarab
    skarab Journeyman
    I do not have more information on this subject for the moment. But I think it depends on the type of material.
    All that you need is in DIY store.
    Yes, all parts are in the SKP.
  12. Mark Carew
    Quick question for you guys before I jump into building one of these. How does one determine the height of the diode from the cutting surface to get the best possible focus or at least to know that you are within the range of the focus for the diode?
    Thanks in advance
    Mark
  13. skarab
    skarab Journeyman
    Hi Mark, I have not make accurate test, but between 3 and 7 cm is ok with my diod. Probably a little more or a little less is ok too.
  14. Mark Carew
  15. skarab
    skarab Journeyman
    With a little thought, I would advise a Z axis .. it would be more comfortable.
  16. Robert Hummel
    Robert Hummel Custom Builder
    Moderator
    Agreed and the three axis board should be done soon, I will send one your way :)
    Bin under the weather but bouncing back
  17. skarab
    skarab Journeyman
    :D:thumbsup:
  18. Pokry
    Pokry New
    Hi
    I need to cool the laser diode 2 W. Can you help me how to do it. Any ideas how to do it. Peltier, head sink?
  19. Tweakie
    Moderator
    A fan assisted heat-sink seems to be the preferred method by others currently using diode lasers.
    Tweakie.
    skarab likes this.
  20. Bedon292
    Bedon292 New
    Love the build. I am planning one myself, and this has been a great inspiration.
    Did you have to fabricate all of the brackets yourself? Or were you able to locate them somewhere?
  21. skarab
    skarab Journeyman
    Thank you :)
    Yes. All parts are 3d printed on my Lautr3k :) I am sure you will easily find a person to print them for you.
  22. Bedon292
    Bedon292 New
    Yeah, I may have someone I can get to print the parts. I will have to play with the design some and see what I can come up with.
    Thanks.
    skarab likes this.
  23. alessandro
    Excellent build. Very good.
    Can you attach your STL files for the 3D printer?
    And a BOM?
    Thanks in advance
  24. Pokry
    Pokry New
    You can download Skechup. Open file the next tab in the browser windowe and find export file dxf or stl. In the second window that pops up you select stl and done.If the friend does not overtake me this evening I can add files.
    Sorry for my gramma.
  25. GorillaBob
    FYI, I know someone that has 2 3d printers... I would need to see the stl or skp files to see what exactly is involved with the prints. Were the originals printed in ABS or PLA?
  26. skarab
    skarab Journeyman
  27. Allan Koch
    Beautiful design !, how do you attach the end pieces to the 20x20 V Slot rail.
    I am new to the 3D printer technique are you able to print the corner pieces with all holes or do you drill some of them afterwards ?
  28. skarab
    skarab Journeyman
    Tanks you @Allan Koch, but the main design is from @Robert Hummel.
    Yes all part is printed with all holes in place :) 3D print is magic ;)
  29. Allan Koch
    :) @skarab, interesting! you didn't answer my question, how the plastic end piece is attached in the middle of the 20x20 V slot rail, how do you fill up the big hole and make a thread in it ? :)
  30. skarab
    skarab Journeyman
    Sorry but I have not understand the question ... A photo will be easier to understand, I callback that I do not speak good English, sorry. 2014-09-30 06.48.45.jpg 2014-09-30 06.51.40.jpg
