Laser Rotary Tool / Attachment
Discussion in 'Laser Cutters' started by pedrofernandez, Oct 30, 2019.
  1. pedrofernandez
    pedrofernandez Journeyman
    pedrofernandez published a new build:
  2. pedrofernandez
    BE sure that the main plate have 155mm wide on your CAM software before cutting, the svg files trend to miss scale
  3. CameronAlp
    Great Build! What thickness plate did you use?
  4. pedrofernandez
    1/4 in thick 6.35mm
  5. BrianJdfwoodwork
    You’re killing it with these builds! Hopefully in the spring I’ll be able to give building the 50w laser a try and build this to go along with it!!
    pedrofernandez likes this.
  6. pedrofernandez
    thanks, for he 50w think about it, if you really want to build or have one because is out know a 60w china for 1500.
    BrianJdfwoodwork likes this.
  7. BrianJdfwoodwork
    Yours clearly works, and is built to be reliable. Those Chinese ones all over eBay I don’t trust as much. I’m mainly wanting a laser for engraving glasses, mugs, and acrylic so the 50w is probably overkill but oh well.
  8. pedrofernandez
    im just telling about it but an own build is an own build any help just let me know
  9. mrp192
    mrp192 New
    Here's mine. I changed it a little bit. Made it so the Nema 17 Mounts to the same plate as the rollers. I should have this finished up this week.
  10. Chris English
    nice idea! Anyway to convert that to support a nema 23?
  11. Lentikular
    Look great, is there a kit of parts available anywhere. I'm in UK
  12. Lentikular
    What are the lengths of the 20x20 rails
  13. MolsonB
    MolsonB New
    Yeah to me that makes more sense to have 1 plate. I wonder what the logic is to have it seperated like that?
  14. JustinTime
    JustinTime Veteran
    I would guess to put the flexible coupling, which I think is not really necessary in this build.
  15. pedrofernandez
    Low Profile !!!
  16. fernando leppaus
    Could you make the project available?
  17. Peter Van Der Walt
    Click the Files and Drawings tab above ^
