Keeping thing quiet with a custom C Beam XL
Discussion in 'CNC Mills/Routers' started by Mirthgiver, Jan 16, 2021.
  1. Mirthgiver
  2. GeoffH
    GeoffH Journeyman
    Hello, I have built a similar machine, but not with sound insulation. I noticed that you will need the enclosure to be larger in the Y direction to accommodate the table movement.
    Good luck with your build, Geoff
    Rhett E and Rick 2.0 like this.
  3. Mirthgiver
    Thanks. I keep forgetting about that. It’s about 150mm either side right?
  4. Rick 2.0
    It's a little more complicated than that. If you're looking to get 350mm usable usable working width in the Y direction the board has to move 350mm both sides of center. At a minimum you'll need 700mm of box depth. But that's just based on board movement. Any excess the board sticks out beyond the usable area (ie. clamping area) and any amount the build sticks out beyond the max range of the board also gets added to the 700mm.
    Truly the best way to keep the system to the minimum form factor such that it can be put in a box is going with a fixed bed system like you already have.
  5. GeoffH
    GeoffH Journeyman
    For my modified machine it's about 350mm overall, plus a bit of clearance.
